Audio Technica ATH-M50 tip replacement
gmcman
gmcman Posts: 1,864
edited August 2015 in Headphones
Long story short, I had them in my son's iPad and upon removal the tip was gone. The tip came out of the socket of the iPad but now I need either a new end or an entire cord.
Has anyone had to replace a cord on these particular headphones? Any recommendations?
They are out of warranty also.
I would like to keep the stress reliever on the end but it's not a deal breaker. I could easily solder a new end but I don't want to compromise anything it terms of SQ.
    edited August 2015
    D A M N! How did you do that? Those M50 ends are solid metal and virtually indestructible, some of the best I've ever seen, on the old models that is-not on the X series which cheapened out!
  • gmcman
    gmcman Posts: 1,864
    I know....I miss them already..my heart sank when I saw this but at least they aren't incredibly expensive but still..unnecessary expenditures.
    edited August 2015
    gmcman wrote: »
    That's impressive! Can't believe what I'm seeing as I sit here looking at mine? But there it is. Hopefully some DIY guys will step in here, I could never repair that. And, unfortunately, if you had the new M50Xs you'd have two other cables to work with and/or could just buy a cable replacement of the same kind and snap it in. The only real downfall of the original M50s. A shame. They're really nice HPs in their price range. I've never bothered to upgrade them, I merely went a little higher with open cans like the HD600s and the AKG Q701s below. Between all three I'm covered for whatever. Portable? I go with the KOSS PortaPros.
    There must be some repair info on Head-fi.org, no?
  • badchad
    badchad Posts: 348
    Can't offer much help, but there are numerous DIY videos on how to switch the ATH M50s over to detachable cables.
    Polk Fronts: RTi A7's
    Polk Center: CSi A6
    Polk Surrounds: FXi A6's
    Polk Rear Surround: RTi4
    Sub: HSU VTF-3 (MK1)
    AVR: Yamaha RX-A2010
    B&K Reference 200.7
    TV: Sharp LC-70LE847U
    Oppo BDP-103
  • gmcman
    gmcman Posts: 1,864
    badchad wrote: »
    I will look into that, thanks.
