Tubes Mostly Preamp
snow
For sale are a few tubes mostly preamp tubes and a few power tubes. All tubes have been tested and test good on my testers and all are used and do not come with tube boxes unless NOS. Most will have some or all the print missing. As always if unhappy for any reason there is a money back guarantee
1.RCA Black plate D getter 12AX7-1-$20.00
2.Hammond labeled- Amperex made grey plate Halo getter 12AX7-2-$25.00 each
3.GE 6201/12AT7WC grey plate halo getter-2-$10.00 each
4.RCA Black plate D getter 12AT7-2-$10.00 each
5.GE 6201/12AT7WC grey plate halo getter-2-$10.00 each
6.RCA Black plate D getter 12AT7-2-$10.00 each
7.RCA Black plate D getter 12AT7-NOS-1-$15.00
8.RCA JRC Black plate D getter 12AT7-NOS-1-$15.00
9.GE grey plate halo getter 12AY7-2-$15.00 each
10.RCA Black plate halo getter 12AV7-NOS-2-$10.00 for the pair
11.Tung-Sol grey plate Halo getter 12AV7-NOS-$5.00
12.RCA JRC 5814/12AU7 Black plate Halo getter-1-$7.50
13.GE 5814/12AU7 grey plate halo getter-1-$5.00
14.Sylvania JAN-6189/12AU7 grey plate halo getter-1-$5.00
15.Amperex grey plate halo getter orange globe 12AU7-1-$5.00
16.Capeheart labeled Black plate D getter 12AU7-1-$5.00
17.Magnavox labeled 6SN7WGT Black plate-2-$50.00 for the pair
18.Sylvania Black plate D getter 12AU7-1-$7.50
19.Tung-Sol Grey plate halo getter 12AU7-1-$5.00
20.RCA grey plate side D getter clear top 12AU7A-2-$5.00 each
21.GE grey plate 12AU7-2-$5.00 each
22.RCA Black plate D getter 12AU7-4-$10.00 each
23.GE JAN 5963/12AU7 grey plate-NOS-2-$10.00 each
24.Sylvania 5963/12AU7 grey plate-NOS-1-$10.00
25.GE 5963/12AU7 grey plate-1-$5.00
26.RCA 5963/12AU7 Black plate D getter-7-$10.00 each
27.RCA grey plate 6BQ5/EL84-1-$10.00
28.GE grey plate 6BQ5/EL84-2-$10.00 each
29.Raytheon Grey Plate 12AX7A-2-$10.00 each
30.Mullard ECC88/6DJ8-4-$$20.00 each
31.Brimar ECC88/6DJ8-1-$20.00
32.HP labeled 12AU7-3- Japanese made likely made by Matsushita on Mullard tooling, these flash like mullards and have seams on top-$5.00 each
33.GE 5965/12AV7/12AT7 sub-50-$2.00 each
Regards Snow
__________________
Regards Snow
__________________
Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Post edited by snow on
Snow,
I might be interested in these:
Juan -
I like to purchase item #15, #19, and #29. Please pm your address. Thanks.Abbas Tube USB-SPDIF Converter with tube clocksAbbas V2 SE Tube DACAltmann Attraction DACNon-Pre passive preampYamaha M2 AmplifierDIY TPA3255 Mono Amps6L6 Williamson amplifier42 SET amp6V6 SET ampMcIntosh XRT18 speakersApogee Centaur MinorPioneer PAX A30 speakers
Hi Snow - I'm in for 2 of those Mullards if Juan passes!
30.Mullard ECC88/6DJ8-4-$$20.00 eachVA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Hey Dan, put me down for:
6.RCA Black plate D getter 12AT7-2-$10.00 each/for the pair
22.RCA Black plate D getter 12AU7-4-$10.00 each/for the quad
Thanks, Mike -
Here are a few pics of the Mullard ECC88/6DJ8's and the Bell & Howell Japanese made 12AU7's for you Juan. As you can see some of the lettering is missing on some of the tubes and they are a bit dirty but I do not want to clean them for fear of losing the print. it looks like they were made in the Blackburn plant in 1966 all 4 are matched codes.
Hey Snow
how about the two #2's - Hammond labeled- Amperex made grey plate Halo getter 12AX7-2-$25.00 each
thanks
Darryl2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Sure Darryl there all yours.
Regards SnowWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Hi snow. I'll take all the tubes I requested. I'm out of town right now but will get squared away with you over the weekend.
Juan
Do you know who made the magnavox 6sn7wgt?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Yes they were made by Sylvania in 6-1950Do you know who made the magnavox 6sn7wgt?
Regards Snow
Thanks everyone I will send out tracking numbers soon to you all, I have been gone out of town.
Regards snowWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
A new list coming soon Lots of NOS tubes and some more used ones 12AX7 types 12AU7 types 12AT7 types and some rare output tubes so keep an eye out and your pocket book open
Hey Snow
What 6sn7 tubes do you have remaining?
Also 6sl7?Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
Joey, if snow can't hook you up with 6SL7's I have some extra's of my favorite. Let snow answer first, but how many do you need?
Hey Snow
Also 6sl7?Hi Joey i have
Magnavox labeled Sylvania made 6SN7WGT Black plate-2-$50.00 for the pair
RCA-CRC-5692/6SN7 Black plate-2-$150.00 for the pair + shipping
Sylvania JAN-6SL7WGT-2-$30.00 + shipping for the pair
Thanks Snow - you are the Man!
