Center channel advice
jfos4
jfos4 Posts: 2
I have a PSW108 sub, a pair of MC60's in the rear ceiling and a pair of MC85i's in the front wall. I'd like any suggestions for a center channel that will sit on a console under the TV. Thanks for any suggestions.
  • jfos4
    jfos4 Posts: 2
    Sorry to go AWOL, just moved into the new house and time is stretched. I have my system set up in a finished basement, about 16x25 that opens up on one side to a bigger area, but the speakers are focused in the 16x25. Center will sit on a console under my TV that is hung on the wall. My receiver is a Pioneer with 110 watts per channel. I am looking for something in Cherry and was weighing options between the CSi A4 (highest end of my budget), the AM2182-A CS2 Series II and the Monitor-25C 2-Way.
  • rpf65
    rpf65 Posts: 2,127
    CSI A4. Looks good in cherry
  • Polkie2009
    Polkie2009 Posts: 3,834
    Welcome into the forum jfos4, here's to hoping you find a sweet cherry center bro. :)
    tonyb Posts: 33,068
    Go with the biggest center you can afford....and fit. That's a fairly good sized room and that sub is also on the light side for a room that big. Thoughts to ponder is all.
  • rooftop59
    rooftop59 Posts: 8,121
    go used brother. those speakers will blend pretty well with anything from the monitor or rti series. I personally would look for a csi5 or a cs409i. As tony said go big on this one.
    Game Room 5.1.4:
    Bedroom 2.1
  • ken brydson
    ken brydson Posts: 8,988
    rooftop59 wrote: »
    CS409i? Thinking you meant CS400i.
