Center channel advice
I have a PSW108 sub, a pair of MC60's in the rear ceiling and a pair of MC85i's in the front wall. I'd like any suggestions for a center channel that will sit on a console under the TV. Thanks for any suggestions.
Sorry to go AWOL, just moved into the new house and time is stretched. I have my system set up in a finished basement, about 16x25 that opens up on one side to a bigger area, but the speakers are focused in the 16x25. Center will sit on a console under my TV that is hung on the wall. My receiver is a Pioneer with 110 watts per channel. I am looking for something in Cherry and was weighing options between the CSi A4 (highest end of my budget), the AM2182-A CS2 Series II and the Monitor-25C 2-Way.
CSI A4. Looks good in cherry
Welcome into the forum jfos4, here's to hoping you find a sweet cherry center bro.
Go with the biggest center you can afford....and fit. That's a fairly good sized room and that sub is also on the light side for a room that big. Thoughts to ponder is all.HT SYSTEM-
lsi 9's -
go used brother. those speakers will blend pretty well with anything from the monitor or rti series. I personally would look for a csi5 or a cs409i. As tony said go big on this one.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
CS409i? Thinking you meant CS400i.
