How To Remove Water Stains On Wood Venner?
Had a water leak in the house and some water dripped on top of one end cap of my 1C's. The wood is walnut veneer which has an oiled finish. What is the best way to go about removing the stains on an oiled veneer finish? Steel wool, sandpaper, just re-oil (I have some teak oil here)? Any advice would be appreciated before I start and potentially make it worse. thanks, don
Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
Power Amp: Sunfire Architect's Choice Series II
Preamp: Adcom GFP-750
SACD/CD: Oppo BDP-95
Tuner: Sansui TU-717
TT: Technics SL-MA1
Phono Pre: Emotiva XPS-1
Music Server: Mac Mini w/JRiver - iPad w/JRemote
DAC: Eastern Electric MiniMax Plus
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
    mhardy6647 Posts: 35,041
    edited August 2015
    those look to be extremely minor -- Howard's Restor-a-Finish followed by Feed-n-Was might be sufficient. A little very fine steel wool (0000 or so) can be your best friend on such projects.
    The canonical answer for water stains (white rings) is still, AFAIK, to use oxalic acid.
    EDIT:
    1) here's some tutorial info: http://www.audiokarma.org/forums/showthread.php?t=286413
    2) having posted this, I just remembered/realized that there are wood finishing pros on this forum -- so take my advice with a big grain of salt! :-P
  • vmaxer
    vmaxer Posts: 5,120
    @F1nut is the man on this.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    F1nut Posts: 51,787
    Do not use Oxalic acid or Howard's stuff.
    Oxalic acid is used for removing dark/black stains caused by a reaction to the tannin in wood, this isn't your issue. Howard's, not in my shop.
    Scrub (with the grain) using a little lacquer thinner and 0000 steel wool. Wipe off with clean rags. This will remove the oil in the wood. You'll have to do both speakers as this will change the appearance caused by years of oxidation. You might have to do this a few times. Once the top is uniform in appearance again, re-oil the tops.
  • stogie
    stogie Posts: 230
    Thank you F1. As far as an oil to use: is teak oil ok? Attached is an image of what I have on hand. The label says it contains "pure Chinese Tung oil" but lists no other ingredients. If not this, what is your recommendation. thanks
    TT: Technics SL-MA1
    F1nut Posts: 51,787
    I'd use a Danish oil such as Watco, but that will probably be ok.
  • stogie
    stogie Posts: 230
    Found some Watco Rejuvenating Oil In the closet from a project last year. Will this work, or is it best to go ahead and get the Danish oil in dark walnut (I assume it has some type of pigment in it) and be done with it? I don't want to have to go back a redo anything. F1, thank you for your help.
    TT: Technics SL-MA1
  • soundfreak1
    soundfreak1 Posts: 3,414
    This might sound stupid but.... since it's vinyl the water probably hasn't obsorbed but is "on top of the vinyl" steel wool might scratch up the finish. I had an ink stain on vinly and used mr. Clean "magic eraser" took ink right off with a few soft rubs. Try it before you damage the vinyl might just work great. Costs a buck or so and is in the grocery stores. You have nothing too loose.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • stogie
    stogie Posts: 230
    It's not vinyl, it's wood veneer.
    TT: Technics SL-MA1
  • soundfreak1
    stogie wrote: »
    That stuff is great on wood. Vinly not so sure. But on wood it is fantastic for cleaning up wood surfaces. I always keep it around and have used it many times but concerned about it on vinly surfaces.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • steveinaz
    steveinaz Posts: 19,545
    Trust F1 on this one, the man knows his wood. No pun intended.
  • soundfreak1
    The OP is talking about vinyl not wood. May be an important diff.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • vmaxer
    vmaxer Posts: 5,120
    Don't think so??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • soundfreak1
    vmaxer wrote: »
    Don't think so??
    My mistake (senior moment ) i stand corrected thought he was talking vinyl not wood veneer. In that case the watkins would be perfect with some 0000 wool and go with the grain..
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    F1nut Posts: 51,787
    stogie wrote: »
    Try it and if it's not dark enough get the walnut Danish oil. It won't be a problem using one on top of the other. You should do more than one coat anyway.
    IMPORTANT: when you're done with each application soak the rags in water, then lay them outside, flat on the ground to dry. You risk burning down your house otherwise.
    msg Posts: 10,452
    what the... lol
    how does that happen?!? spontaneous combustion? or fumes to ignition source?
    F1nut Posts: 51,787
    Yep, spontaneous combustion. Wasn't long ago I read about a house burning down because the owner left some of those oil soaked rags in the garage, which burst into flames. Last year one of the shops in the area burned down for the same reason and he knew better.
  • Nightfall
    Nightfall Posts: 10,084
    edited August 2015
    We keep our kitchen rags in large totes at work. One day we smelled smoke, walked around looking for it. Saw smoke pouring out of one of the totes and dumped the lot into the grass outside and sprayed them down with a hose. Nobody knew why this happened, so it was because of the grease in them?
    We're lucky it happened during business hours.
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 51,787
    Nightfall wrote: »
    I'm not aware of kitchen grease having spontaneous combustion issues, but that's out of my field. Perhaps someone's hot sauce......LOL
  • stogie
    stogie Posts: 230
    Thanks for the info on cleaning the rags- I never knew.
    TT: Technics SL-MA1
  • leftwinger57
    leftwinger57 Posts: 2,917
    As you see the dark water stain that was on my 2Bs is what Jesse and others were talking about. I went w/ Jesse's help the oxolic route and be very careful.The package is for doing a whole deck.What's needed is a paste type mixture and since water is in the mix be very careful because you can warp your top worse than the actual stain. In my case it worked and then after some minor sanding and tack cloth I used medium walnut stain and about 5 coats of Minwax poly clear.ymhkfzhuht6o.jpg
  • stogie
    stogie Posts: 230
    Before and after pics. The 0000 steel wool and lacquer thinner wasn't getting all the water stain out so I hit it with some 320 sand paper and that did the trick. Three coats of Watco Rejuvenating Oil and presto. It looked so good I went ahead and did the other speaker.3acb2m9pyu4z.jpg
    TT: Technics SL-MA1
  • westmassguy
    westmassguy Posts: 6,850
    Nice work!
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    We have a very old table with a badly watermarked top -- the good information (as opposed to my disinformation! :-P ) in this thread has led me to plan to tackle it when the weather cools down (and life quiets down some from its current, too-hectic pace).
  • Looks great Stogie! And thank you to F1nut for the info.
    HT: Marantz NR-1603, Oppo 981, Def Tech SM55, SVS PB-1000
    BR: iPad Mini, Audio Engine A5+
    2C: Parasound ZDAC V.2, Sony DA80ES, Sony XDR-F1HD, SVS Prime Tower, JSE .6 Infinite Slope
    Office: MBAir, Focusrite Scarlett 2i2, JBL LSR-308
    Projects: Polk RTA12, Polk Monitor 7, Revox B225CD, BIC 3-TM
    F1nut Posts: 51,787
    Looks good...yeah, a light scuff sanding is needed at times, but I try to avoid it if at all possible.
    treitz3 Posts: 20,006
    Well done my friend. The end result looks great.
  • steveinaz
    Nice save!
