Looking for BEEFY spikes?
F1nut
F1nut Posts: 51,755
  • headrott
    headrott Posts: 5,496
    Whew! Those look nice Jesse! I am thinking the set I got from you!
  • CoolJazz
    CoolJazz Posts: 572
    The first spikes that a pipe wrench is recommended for installation???
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
    F1nut Posts: 51,755
    Good idea. If you want BEEFY spikes be sure to check out the Adona multi-element cones as well. I put a set on my HT sub....major improvement.
    http://www.adonacorporation.com/tweaks.html
  • Joey_V
    Joey_V Posts: 8,600
    Jesse
    Have you dealt with still point spikes?
    Toolfan66 Posts: 18,046
    edited August 2015
    I used Adona spikes for my Adona themed rack that I built a few years ago, they are great spikes..
    edited August 2015
    tonyb Posts: 33,072
    No spikes on the Minions ? My wife would steal those puppies in a heartbeat. Ya need the Evil ones and the dog too bro.
    Nice rack....and spikes btw.
    Haha!! I bought those for my daughter and that's where she keeps them..
    F1nut Posts: 51,755
    Joey_V wrote: »
    Jesse
    No, I haven't.
    I am aware that Stillpoints takes a different view than most in that they believe decoupling your speakers from the floor nets a better result. While that may be true in some cases I have not found it so. However, when it comes to monitors I have found they sound best decoupled from coupled mass loaded stands. Figure that one out.
    The following is a good read on coupling/decoupling.
    http://www.whatsbestforum.com/showthread.php?4253-Understanding-Coupling-Decoupling-with-particular-reference-to-loudspeakers&p=71837&viewfull=1#post71837
    F1nut Posts: 51,755
    Toolfan66 wrote: »
    Very nice B)
    txcoastal1 Posts: 13,512
    Joey_V wrote: »
    Jesse
    No, I haven't.
    This is where one shoe doesn't fit all...(application that is) example...
    Russ put together a pair prototype sealed speaker. We listened to them for hour at his house (coupled) on concrete with loaded stands great bass extension and handling. The next day took them over to Skips and the bass fell apart. While we were scratching our heads and trying to better the speaker position we found the bass was running straight into the ground. We had the on Skips second floor, this location required the speakers to be decoupled to get the bass extension.
