question about passive radiators, yeah after all these years
I get that it takes a bunch of air to move the passive to perform it's best and make any said speaker go down even lower than a hot bass driver. My question is if we all w/ vintage Polks deaden the air space w/ poly fill up top, Dynamat on the baskets and Black Hole-5 the most potent of deadening material known, how does this passive still produce unheard of slamming lows if all drivers are front firing ? Please if there is a math formula involved go easy on me I failed algebra 1 about 7 x and they didn't know what to do w/ me....
http://www.centerpointaudio.com/PassiveRadiators.aspx
    heiney9 Posts: 25,445
    A Passive Radiator is nothing more than a different type of port. It has it's advantages and disadvantages
    http://www.aespeakers.com/PRFAQ.php
  • audio_alan
    audio_alan Posts: 770
    I'd guess it still works because the drivers are still producing cabinet pressure (which must be released via the passive moving). The polyfill, blackhole-5, etc is only in there to help reduce sound reflections. I don't think the fill would change cabinet pressure much either way...
  • leftwinger57
    leftwinger57 Posts: 2,917
    Finally, A real answer. Thank you that does make sense.
  • drumminman
    drumminman Posts: 3,396
    That's my understanding too.
