Parasound HCA 2200 II
simm
simm Posts: 602
edited August 2015 in Vintage Speakers
Will the 2200 series II amp work with SDA's without having an A1? If so what is a fair price for these amps?
  • Schurkey
    Schurkey Posts: 2,122
    edited August 2015
    Your answer seems to be buried in this thread:
    http://forum.polkaudio.com/discussion/152902/common-ground-amps
    IF I read this right, the amp has a 5.6 ohm resistor between each of the negative terminals and chassis ground. Thus about 11 ohms between the two negative terminals.
    You will want to install a jumper wire to bypass that resistance--or if your speakers allow using an isolation transformer, (AI-1 or "Dreadnaught") that can be used in place of the jumper wire.
    Please confirm this info on your amp with an ohmmeter across the negative terminals of the two channels--or--contact Parasound.
