worth something?
Answers
  • voltz
    voltz Posts: 5,384
    edited August 2015
    Welcome to Club Polk! It depends on which SDA it is and does it have a pin/blade connector or blade/blade? the condition of the drivers & Pr. more pictures with the grills will help
    But welcome!
    msg Posts: 10,462
    probably $12k - $15k depending on the model and condition.
    post more photos and info and we'll tell you.
  • vmaxer
    vmaxer Posts: 5,121
    voltz wrote: »
    But welcome!
    Appears to be pub/blade.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,121
    And welcome!! Stick around.
    Are you using them??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ken brydson
    ken brydson Posts: 9,020
    vmaxer wrote: »
    voltz wrote: »
    But welcome!
    I've never done well with pub blade.
  • vmaxer
    vmaxer Posts: 5,121
    edited August 2015
    D@mn iPhones and spell correct >:)
    But it is the latest technology!! (Pub/blade)
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • smglbrth
    smglbrth Posts: 1,498
    jz1306 wrote: »
    :/ ...how much?
    Whatever someone is willing to pay...
  • Nightfall
    Nightfall Posts: 10,083
    msg wrote: »
    Don't try to rip the guy off. They're worth $20k easy.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • jz1306
    jz1306 Posts: 7
    Yes!!!Thank you!!!
  • jz1306
    jz1306 Posts: 7
    Where I can see the model num??
  • jz1306
    jz1306 Posts: 7
    Do you need some more pic???
  • [Deleted User]
    [Deleted User] Posts: 10,716
    This is what I would do: Go in to work and your boss and tell him what you really think of him and then sell these in the flea market. Just me though.
  • MrBuhl
    MrBuhl Posts: 2,419
    Hi - welcome to Club Polk - stick around for a while you will find some great information here in addition to that about your speaks.
    They would appear to be pin/blade SDA SRS 1.2's of some version - if you go here you can research a lot more about them, you may have to pull some drivers (carefully) to determine exactly which model you have.
    http://gimpod.com/sda-id.html
    Though it seems like a smart answer, it's true, they are worth what someone will pay for them based on condition, functioning of drivers, etc so you've got some research to do that can't be done via photos. Get out a screwdriver and get your learn on to get the most out of them.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
