Official SVS owners thread!
1356720
  • oldrocker
    oldrocker Posts: 2,590
    Oh yeah, we here a "distant" thump from time to time. B)
    EndersShadow Posts: 17,704
    edited August 2015
    oldrocker wrote: »
    @oldrocker You think you hear a thump now... check my thread...
    I'm shooting for 2 hz now :smile:
    Make folks sign a waiver if they have a pacemaker or any heart issues before they can come in the house :smile:
  • oldrocker
    I just saw read it.
    Oh you young whipper snappers and your toys... :D
  • afterburnt
    afterburnt Posts: 7,892
    Sami wrote: »
    I cannot comment on the particular subs as I don't have experience with them but one higher end my preference. You might get slightly higher output with two (or not) but most of the time the higher ends output is, well, higher end. You'd probably tighter, less boomy bass out of it. Especially if the system is used for music I would lean towards a higher end model. Plus your upgrade path next time is easier...
    Easier? I am affraid I will end up with two $1300 subs. Somebody stop me!
  • afterburnt
    SVS Merlin says that I need the $2000 sub
  • Sami
    Sami Posts: 4,634
    Well, I have the $2k sub but Merlin is suggesting $800 subs. I currently have Magnepan MMG's on a very large room with a PB13 Ultra. For LSi9's that I have in the theatre room it recommends up to PB12 Plus, SB13 Ultra or PC12 Plus. I think the current PC-Ultra works fine with them and is on line with the suggestion. I would definitely take such a generic recommendation with a grain of salt.
  • mikeyb128
    mikeyb128 Posts: 2,885
    The pb12 plus is a great sub and excellent value. I would love to try a cylinder sub in the back of my room due to space constraints.
    You might as well buy 4 ultras and call it a day.
    2 channel:
    Theater:
  • afterburnt
    @mikeyb128 what are you running your PB12+ with?
    It is good that I can only squeeze one more sub in here or else I would be thinking about 4, that would rule lol!
  • mikeyb128
    afterburnt wrote: »
    I use 2x pb13 ultras with lsim 705 and 706c :smile: there is no shortage of sub power in my room.
    2 channel:
    Theater:
  • mikeyb128
    nbrowser wrote: »
    mikeyb128 wrote: »
    afterburnt wrote: »
    I almost thought about smuggling one of those out of the house... :wink:
    Lol! It would probably fold you in half! I fit one in my golf and managed to get it out of my car and into the house alone!
    2 channel:
    Theater:
  • Nightfall
    Nightfall Posts: 10,084
    That's insane. I like it.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Sami
    Sami Posts: 4,634
    Nightfall wrote: »
    I say he needs to go down to 1Hz as then he can play digital...
  • Kurt300
    Kurt300 Posts: 302
    mikeyb128 wrote: »
    nbrowser wrote: »
    mikeyb128 wrote: »
    afterburnt wrote: »
    Just when I thought I was relatively satisfied, you guys are making me lust after the PB13-Ultras...trying to convince myself that I could re-purpose my PB12-Pluses to the BR and PC setups...
  • afterburnt
    Gonna order a second pb 2000 boy my first pb 2000 looked like a wasing machine. Next to these 707 it looks like a lunch box
  • gce
    gce Posts: 2,158
    SVS is having a moving sale if your looking for something from them now's the time.
    http://www.svsound.com/
    Anaheim Hills CA,
  • afterburnt
    Got my second PB 2000, what should I xo my speakers at?
  • afterburnt
    I merlined them
  • afterburnt
    werks gud, I thought I should run the 707's lower but 60 is fine
  • afterburnt
    hey this merlin thing says to use 40hz for the LsiM705 but says to use 60hz for the LsiM707
  • rpf65
    rpf65 Posts: 2,127
    Merlin is a guide. It can't account for every unique situation. For instance the 705s are better suited for a mid size room, while the 707s are better suited for a larger room.
    To get proper bass response the whole room needs to be pressurized. Given the same amount of amplification for each speaker, that would make sense. Just a guess on my part about the algorithm parameters.
    SVS spends a lot of money on their customer support side of the business. If your having trouble getting a sub dialed in, they can help.
    Actually think those guys are issued squeeze balls for stress relief. Can't really understand why the the phrase "look you moron/idiot I said:" isn't used more often.
  • afterburnt
    That would be an Imbecile
  • afterburnt
    edited September 2015
    SVS said 60hz would be betterbut I figured that out when subs would stay off most of the time when set to auto. Everything is set to 60 or 800 now to play around with the center xo
  • The SVS tech team is the biggest creator of sales that SVS has. I have NEVER heard anything negative about them...No chance of them ever getting outsourced.
    Garage | Polk Monitor 5B's
  • Willow
    Willow Posts: 11,233
    Tonight I am having delivered an PB 10 NSD I found used locally. I am looking forward to joining the SVS family. I'm sure it will beat my Energy 10.2. I am contemplating using both not sure yet. I have a funny feeling I'll want to get a 12" in the coming years.
  • Mikey081057
    Mikey081057 Posts: 7,127
    Conrats!! you will not be disappointed
  • rooftop59
    rooftop59 Posts: 8,121
    Willow wrote: »
    I have that svs in the living room and have a mirage in the bedroom that is very similar to your energy. In a smaller room with most music you wont notice much difference. However, in a larger room or with movies with deep LFE you will notice a HUGE difference.
    As for using both, the best HT setup I've had used a sub to supplement the center channel and then a big bad LFE sub. So much bass comes through the center that it really made a big difference. You should try it if you have space.
    Game Room 5.1.4:
    Bedroom 2.1
  • Willow
    rooftop59 wrote: »
    Willow wrote: »
    Thanks guys looking forward to it. Our room is 12'w 21'long and 9' high. It is 98% DD+ Netflix and movies.
  • Willow
    Sub for in the house, didn't calibrate it yet as kids wanted to watch while I made dinner. Once they are in bed I'll try to play with it a bit. However I came home to find our Internet is down so I have to call to give them heck that's twice in 24 hrs.
  • afterburnt
    rooftop59 wrote: »
    Willow wrote: »
    I was going to try that center sub thing but had no room to do it. How did you hook up a sub to your center?
  • Willow
    afterburnt wrote: »
    rooftop59 wrote: »
    Willow wrote: »
    You need the speaker cable input in the sub. You can't use LFE directly.
