3D Printing Adventures
VR3
So after months of lots of trial and error, I am slowly getting the hang of 3D printing... it has been the most frustratingly enjoyable thing to mess with ever!
It has came a long way lately.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Thank you sir!
This is the biggest thing I have printed (with success) and even then, I questioned the potential outcome
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Very cool Tray. I'm a Quality Manager at a machine shop and we're thinking about getting one of these for R&D work. Looks like you have the resolution set on the high side. How long did it take to make?Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Thanks guys
I have learned a lot about resolution in the sense you can set the printer to low/med/high resolution but the layer HEIGHT is actually more important than the resolution in and of itself.
IE: A low resolution print (faster) with a low layer height will actually be a faster high resolution print.
So, in this instance, this Buddha print was printed on standard resolution with a .25 mil first layer and a .10 mil layer after that for a total of 933 layers.
It took 17.5 hours to print start to finish.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Buddha? I was expecting a Transformer.Political Correctness'.........defined
President of Club Polk -
LOL.....Yes Sir, his affliction for those little 'bots is well documented. I thought Trey had matured enough to 3d print some naked women though. Maybe a few more years.....
lsi 9's -
I think she'll be a little to "stiff" for his tastes. Besides, nobody likes plastic ****.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
