707 how hard should I push em?
afterburnt
afterburnt Posts: 7,892
I am trying to warm em up and break em in. Can I push them too hard? I just want to play my album's
  • voltz
    voltz Posts: 5,384
    Bruce
    Just play them at normal listening levels, no reason to damage your hearing , but all speakers need a burn in period to sound their best, about 200 + should do it :)
    msg Posts: 10,452
    what are you running them on?
  • mikeyb128
    mikeyb128 Posts: 2,885
    Till you let the smoke out :wink:
    2 channel:
    Theater:
  • mikeyb128
    Honestly though. How are you liking them so far?
    2 channel:
    Theater:
  • afterburnt
    Maybe200nwatt og a31
  • Nightfall
    Nightfall Posts: 10,083
    edited August 2015
    Leave them playing the radio 24/7 when you're not listening.
    Your setup has really stepped up in a short amount of time, congrats man! How about some pictures?
    Might I suggest your next upgrade? Parasound P5. The HT bypass would be perfect for you.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • afterburnt
    afterburnt wrote: »
    Tablet translation: Maybe 200 watts on a Parasound A31
  • afterburnt
    Nightfall wrote: »
    I have no radio reception where I live so I leave Pandora on but it turns itself off eventually.
    The next conquest is going to be the 706c. I just got a Yamaha RX-A2030 what kind of improvement would a P5 provide?
    gudnoyez Posts: 8,172
    You got some LSIM 707's congratulations and a Parasound A31 double congratulations. All I can say is Easy big fella, your spose to ease into this hobby and not go ape..it all at once, are you going to hoard all your other stuff as Tony B would say Seeeesh.
  • afterburnt
    gudnoyez wrote: »
    @gudnoyez I pretty much decided not to retire early (hope I am not forced to) so that freed up some funds. This is about the only fun that I have and every move that i have made has given me a lot of satisfaction. I am almost done now. Famous last words lol!
  • mikeyb128
    Lol! "I'm almost done".... I will be done with this hobby when I'm broke. Broke from cars, audio gear, and tools.
    2 channel:
    Theater:
    msg Posts: 10,452
    afterburnt wrote: »
    afterburnt wrote: »
    lol, I figured, but I have been studying up on my Tabletese lately so got most of that.
    re: the break-in and listening levels, like V said - just normal.
    good modest to moderate listening levels running all 24/7, or as much as you can, will get them loosened up and broken in in no time. I haven't heard 707's, but the 703's I use got a bit fuller and smoother after running them a while. you'll see.
    msg Posts: 10,452
    so you're driving everything off of the Yamaha 2030?
    man, yeah, like NF says, you might want to consider a 2ch preamp like the P5. I wonder how you'd like that. depending on how much of the advanced technology of the Yamaha you're using - the streaming/network playing stuff - moving to a preamp w/HT bypass might complicate things a little bit for you, and you'd need to add another piece for these services, like a Squeezebox or Sonos. if you're not using these services, that make things easier.
    how's that HT bypass work? using the HT bypass jacks on the P5 and going to the Yamaha's Inputs? and how would the center channel running on the A31 work in this configuration?
    I also use a 706 with 703's. you'll probably find the 706 to be a nice addition to your Parasound and LSiM setup.
  • afterburnt
    monosodiumglutamat I am running everything off of amps except for the presence speaker, they are riding the Yamaha.
  • afterburnt
    Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1, 9 channels hooked up
  • afterburnt
    I don't understand HT bypass can anyone explain this to a knucklehead?
  • afterburnt
    oh and as far as breakin goes I am running all 9 channels because most of it is new sort of. The RX-A1040 was 7 channels only. I did run my test blue ray(pacific rim) for my daughter when she cam over. At first take I am not sure that I need a second sub but I still want one. I got issues.
  • voltz
    voltz Posts: 5,384
    edited August 2015
    HT bypass allows you to hook up a 2-channel preamp to your AVR but if you just want to listen to 2 channel music - then you leave the AVR turned off... and use the P-5 for 2 channel music..then when you want to play multichannel music or movie you use you AVR and leave the P-5 turned off.
    reason being that music feed thru the P-5 for 2 channel will sound better then music going hru a AVR that is a jack of all trades but a master of none!
    But I think you need to pack up your speaker and send them to me to be properly burned-in as I don't want you to mess this important part up. I send them back in a few months or so hopefully :wink:
  • Kurt300
    Kurt300 Posts: 302
    "I am almost done now." <== This is signature material.
  • afterburnt
    voltz wrote: »
    Sure Darryl you just have to come and pick them up. Bring a truck they won't fit in a sedan.
  • afterburnt
    oh and I guess I am not done. I need a P5...skip???
  • motorhead43026
    motorhead43026 Posts: 4,017
    edited August 2015
    See Skip, I have a (P5) on the way myself.
    – Kevin Alfred Strom
    The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
  • afterburnt
    Now i got to buy another shelf lol
  • afterburnt
    goly guacamole! 200 hours???
  • mikeyb128
    edited August 2015
    200 hours will fly by. Seriously. Dam, I want to try a p5, but I'm not convinced it will outperform my benchmark dac1 pre.
    2 channel:
    Theater:
  • Nightfall
    afterburnt wrote: »
  • ukcolin99
    ukcolin99 Posts: 286
    msg wrote: »
    Dang that looks familiar.
  • afterburnt
    dskip is the phono stage in a P5 good?
  • afterburnt
    Do you think that the P5s Burr Brown would be better than the dual Sabres in the yamaha? Also would the yamaha be of any use if got a P5?
    The Yamaha.....depends if you want HT or not. As far as the dacs go, listen to both and see which you prefer. There's more to it than just dac chips.
