Computer suggestions please
Looking for a new computer to check email, surf the web and stream USB 3.0 digital data to my DAC. Any suggestions?
    EndersShadow Posts: 17,718
    The USB 3.0 will be the only real thing to double check. Otherwise it just depends on your budget and needs.
    Do you want a touchscreen, how big of a screen do you want, backlit keyboard (I'd suggest one they are nice in low light scenarios), etc....
  • nguyendot
    nguyendot Posts: 3,594
    Such an open question, you can choose from so many things! I currently use my desktop I built, but my Surface Pro3 works pretty well too
    Main Surround -
  • Wardsweb
    Wardsweb Posts: 942
    I was thinking something small form factor. I already have a 28" monitor.
    HP makes a little round "puck" that reminds me of a MAC mini and they are cheap.
    Wardsweb wrote: »
    Gotcha, I thought you were talking laptop. If you want something that sized check out Intel NUC units (link)
    Otherwise if your handy like I think you are, you could build a small MiniITX DIY computer for probably around 3-400 hundred that used a integrated graphics card, a solid state drive for the operating system and all the other bells and whistles you'd need.
    But not sure if your wanting DIY or not.
    txcoastal1 Posts: 13,518
    I use a Intel NUC for my music server with external WD USB 3.0 hard drives. I can pack it up in a small box and take it any where. It's what I used at LSAF this year.
  • dhart86
    dhart86 Posts: 1,594
    I bought on of these....... web surfing and audio via jriver. I works very well
    cost me 190
    http://www.amazon.com/gp/product/B00KU54KPQ?psc=1&redirect=true&ref_=oh_aui_detailpage_o09_s01
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
  • HP, Asus, Dell all have similar system either running Celeron J1800 (lower power use) or you could be on look out for Lenovo M tiny series on fleabay. I have a M73 tiny which is dead quiet in my music room.
  • Polkitup2
    Polkitup2 Posts: 1,642
    edited August 2015
    I have used both a Dell Inspirion laptop and a Mac Mini each with I5 CPUs and 8 GBs memory. I used JRiver for playback on both. They both got the job done and were not impacted by web browsing while listening. Overall, I prefer the MAC because of its small size.
  • voltz
    voltz Posts: 5,384
    Dell has factory refurbish PC's that I'd recommend if going that way.
    I have bought many in the past for my brother and for a simple 2nd PC to have on hand.
  • machone
    machone Posts: 1,562
    txcoastal1
    How quiet is the NUC? I have been looking at one.
    My biggest complaint with my Dell laptop is fan noise. I am using Korg Audiogate3 upconverting 44.1Khz files to DSD 5.6Mhz on the fly so I need decent computing power with no fan noise. Also I would want to power it an electrically quiet power supply.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    machone wrote: »
    txcoastal1
    Dead quiet, no fans, use WD USB 3.0 hard drives for music storage.
