Low Bias/High Bias
Was just brought to my attention I have been running my amp in low bias. Getting ready to switch it over to high and see if I hear a difference. Any thoughts?? Probably wont get to it until tomorrow as I have a pile of cd's I need to rerip tonight.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    johny I find that high bias on tube equipment results in more bass and slam with better mids.
  • tophatjohnny
    tophatjohnny Posts: 4,186
    http://www.libertyaudio.com/products/b2b-100-all-mos-fet-stereo-power-amplifier
    Not a tube amp. Looking forward to switching over to high bias though. Thanks
  • tophatjohnny
    Well, this has to go down as one of the dumbest threads I have had the opportunity to start!! :) The difference was that of having a dimmer switch on (let's say) a dining room light and while the light was at the half way position for the longest time, then someone all of a sudden slides that dimmer switch all the way up!! HELLO!!!!!! Ya see, I know so darn little about this hobby and not ashamed to admit. It's an ongoing thing for sure...and this was one of them learning experiences for me. I know I should get to know my gear better and not have to even admit this stupidity, so forgive me please. :p This is really only the first amp I have owned that had such a switch on it. Maybe someone else here has this same option and has played with the back and fourth?? I'm not playing with it anymore...although it does make the beast warm up a bit more!!! Ok, I'm stuck on HIGH!!!! :)
  • Polkie2009
    Polkie2009 Posts: 3,834
    No worries mate, there is no shame bro! We've all been there before . ;) What amp are you running there?
  • teekay0007
    teekay0007 Posts: 2,289
    Not so fast there, Pal! There's so many to choose from....I think we should put that up for a vote. :p
    Glad you're enjoying your new system, Johnny!
    tonyb Posts: 33,068
    Glad your digging your new found love for hi-bias. Don't feel bad though, we've all done dumber things than that by a country mile.
    Once you step into higher end gear, the norms your used to from the consumer grade junk at BestBuy get thrown out the window. Get to know your gear, Talk to Peter, ask questions, soo many great audio companies headed by great guys.
  • tophatjohnny
    tonyb wrote: »
    Thanks Tony and yeah Peter has been real good to me. The change is sure a nice one. Like having a new rig!!
