Better source macbook air or squeezebox touch?
Ok guys, I know the answer to many will be "listen and decide for yourself" but, I'm interested in what would be better from a tech standpoint for a source fed into a dac, a macbook air running tidal through USB into my hegel or, using my squeezebox touch via digital coax into the hegel running tidal through a third party plugin on it.
Any thoughts? Experiences?
  • rooftop59
    rooftop59 Posts: 8,121
    My only thought is does the doc have asynchronous sub input? If not the touch is the better option. Other than that I don't know that there will be much difference...
    Game Room 5.1.4:
    Bedroom 2.1
  • WagnerRC
    WagnerRC Posts: 2,204
    I am using a modded touch with az cables with s4 speakers and I am very happy with the performance. This is one hell of an office set up.
  • RamZet
    RamZet Posts: 792
    At my house I think Tidal sounds the best coming from the Squeeze Box.
    B&W CM9Classé Sigma
  • polk500
    polk500 Posts: 1,171
    Not quite the same I've try a few difference set-ups and Spotify (tried tidal like Spotify more) from the Squeeze Box analog to Yammy sounds pretty good.
    tonyb Posts: 33,072
    grimmace19 wrote: »
    Basically it comes down to using the Hegel's USB or digital coax connections....if I understand this right. Guess that all depends on how well the USB is in the Hegel but my guess is....you'll like it a tad better than the digital coax.
