3D Printing Adventures
VR3
VR3 Posts: 29,534
So after months of lots of trial and error, I am slowly getting the hang of 3D printing... it has been the most frustratingly enjoyable thing to mess with ever! :p6vimh9zc6i4v.jpg
  • vmaxer
    vmaxer Posts: 5,120
    It has came a long way lately.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    VR3 Posts: 29,534
    Thank you sir!
    This is the biggest thing I have printed (with success) and even then, I questioned the potential outcome :p
  • gce
    gce Posts: 2,158
    Very cool Tray. I'm a Quality Manager at a machine shop and we're thinking about getting one of these for R&D work. Looks like you have the resolution set on the high side. How long did it take to make?
    Anaheim Hills CA,
    VR3 Posts: 29,534
    edited August 2015
    Thanks guys :)
    I have learned a lot about resolution in the sense you can set the printer to low/med/high resolution but the layer HEIGHT is actually more important than the resolution in and of itself.
    IE: A low resolution print (faster) with a low layer height will actually be a faster high resolution print.
    So, in this instance, this Buddha print was printed on standard resolution with a .25 mil first layer and a .10 mil layer after that for a total of 933 layers.
    It took 17.5 hours to print start to finish.
    F1nut Posts: 51,944
    Buddha? I was expecting a Transformer.
    LOL.....Yes Sir, his affliction for those little 'bots is well documented. I thought Trey had matured enough to 3d print some naked women though. Maybe a few more years..... ;)
  • mrbiron
    mrbiron Posts: 5,721
    I think she'll be a little to "stiff" for his tastes. Besides, nobody likes plastic ****.
