Monitor 5b and 5jr+
cortico
cortico Posts: 587
edited July 2015 in Vintage Speakers
I have been doing A B comparisons between my recaped speaker sets.
Beyond the obvious different cabinet sizes and crossovers, I wonder why they sound so different. Sure they both are monitors 5, but there's nothing in common between the two, I would think.
the jr+ (With sl2000) sound a bit louder across the range, brighter, more pronounced mid range I love andnice bass too.
The 5b (with rdo194) sound wider, mellow highs and mids. The bass goes depper, rounder and much more defined.
Can't tell which set I prefer...
  • boston1450
    boston1450 Posts: 7,758
    edited July 2015
    Yup. Both great speakers. I had a pair of 5a's with the peerless tweets on tilt stands & i paired them to a small 20wpc Sansui G receiver & it was pure bliss. Those 5's are a bang for the buck
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • soundfreak1
    soundfreak1 Posts: 3,414
    A/b ing can be confusing sometimes. I would pick one pair listen for a few days allowing your ears to get accustomed to the speakers, than switch. Listen for a few days get your ears accustomed to that pair than switch again and listen foe differences! Hear what is missing more than the differences per say!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • decato
    decato Posts: 189
    The crossover network of the Monitor 5 is quite different from that of the 5jr+. The 5jr+ has more midrange, largely due to the simple low pass filter in its design. The 5 will naturally have more bass because of the larger internal cabinet volume and passive radiator.
