Monitor 5b and 5jr+
cortico
I have been doing A B comparisons between my recaped speaker sets.
Beyond the obvious different cabinet sizes and crossovers, I wonder why they sound so different. Sure they both are monitors 5, but there's nothing in common between the two, I would think.
the jr+ (With sl2000) sound a bit louder across the range, brighter, more pronounced mid range I love andnice bass too.
The 5b (with rdo194) sound wider, mellow highs and mids. The bass goes depper, rounder and much more defined.
Can't tell which set I prefer...
Yup. Both great speakers. I had a pair of 5a's with the peerless tweets on tilt stands & i paired them to a small 20wpc Sansui G receiver & it was pure bliss. Those 5's are a bang for the buckRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
A/b ing can be confusing sometimes. I would pick one pair listen for a few days allowing your ears to get accustomed to the speakers, than switch. Listen for a few days get your ears accustomed to that pair than switch again and listen foe differences! Hear what is missing more than the differences per say!Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
The crossover network of the Monitor 5 is quite different from that of the 5jr+. The 5jr+ has more midrange, largely due to the simple low pass filter in its design. The 5 will naturally have more bass because of the larger internal cabinet volume and passive radiator.
