Old Timer - With New-To-Me 1.2TLs
I am FINALLY ready to begin bringing a pair of 1.2 TLs back to life. I need to start with the tweeters, because they are all missing... :-(
I have been reading and it seems the RDO-198 is the ideal replacement. Is this correct ?
Is it possible to order them online ?
Thanks for any assistance you can provide.
B-Man
    nooshinjohn Posts: 25,962
    Call Polk customer service to order them and tell them you are a member here. That will save you some coin on the 198's
    Welcome aboard
  • vmaxer
    vmaxer Posts: 5,120
    Welcome to the club, we will help drain your wallet. o:)
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • [Deleted User]
    [Deleted User] Posts: 10,716
    Yes welcome and have fun! B)
  • Moose68Bash
    Moose68Bash Posts: 3,843
    Welcome!
    You have a fun --and potentially costly -- project ahead of you.
    But, you will find all the guidance you need on this Forum, and, most important, you will be richly rewarded with great sound if you fully mod those 1.2TLs.
  • smglbrth
    smglbrth Posts: 1,496
    vmaxer wrote: »
    Welcome to the club, we will help drain your wallet. o:) [/quote
    You probably don't need help with this to start out with, considering you are looking at $400 bucks in tweeters (with the Polk discount) just to start...
    Welcome, BTW!
  • B-Man
    B-Man Posts: 13
    Thanks for all the replies. I will go with the RDO-198s since none of you screamed in horror about the question. :-)
    Nice group of folks here - I appreciate the welcome and the warnings...
  • boston1450
    boston1450 Posts: 7,758
    Yup. You will enjoy the 198's. They sound superb
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • drumminman
    drumminman Posts: 3,396
    Yes, the RD-0198's are the correct replacement tweeter, and also an upgrade from the stock SL3000's that were originally used.
    Lots of great DIY posts here on the forum on other upgrade projects, including rebuilding the Xovers, replacing the Big SDA inductor, replacing the inductors on the Xover Boards, Dynamatting the driver baskets, Larry's Rings or Hurricane Nuts, installing Black Hole 5, etc.
  • leftwinger57
    leftwinger57 Posts: 2,917
    Lots of well meaning help here if you want it. Not only accept the advice but use it to it's fullest potential. 1.2TLs, very nice place to start as far as SDA speakers go. With all that, yes the RDO-198 and go w/ this a first and easy drop in mod. Many,many threads on full upgrades all depending on your way of doing things and down to the simplest and least expensive way to go about it, Read on most member's sigs to see what was accomplished by each member usually over time.
  • machone
    machone Posts: 1,561
    I followed the suggested recommendations and the results were spectacular. The guys on this forum will guide you right.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
