Old Timer - With New-To-Me 1.2TLs
B-Man
I am FINALLY ready to begin bringing a pair of 1.2 TLs back to life. I need to start with the tweeters, because they are all missing... :-(
I have been reading and it seems the RDO-198 is the ideal replacement. Is this correct ?
Is it possible to order them online ?
Thanks for any assistance you can provide.
B-Man
B-Man
Call Polk customer service to order them and tell them you are a member here. That will save you some coin on the 198's
Welcome aboardThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Welcome to the club, we will help drain your wallet.
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Yes welcome and have fun!
Welcome!
You have a fun --and potentially costly -- project ahead of you.
But, you will find all the guidance you need on this Forum, and, most important, you will be richly rewarded with great sound if you fully mod those 1.2TLs.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
[/quote
You probably don't need help with this to start out with, considering you are looking at $400 bucks in tweeters (with the Polk discount) just to start...
Welcome, BTW!Remember, when you're running from something, you're running to something...-me -
Thanks for all the replies. I will go with the RDO-198s since none of you screamed in horror about the question. :-)
Nice group of folks here - I appreciate the welcome and the warnings... -
Yup. You will enjoy the 198's. They sound superbRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Yes, the RD-0198's are the correct replacement tweeter, and also an upgrade from the stock SL3000's that were originally used.
Lots of great DIY posts here on the forum on other upgrade projects, including rebuilding the Xovers, replacing the Big SDA inductor, replacing the inductors on the Xover Boards, Dynamatting the driver baskets, Larry's Rings or Hurricane Nuts, installing Black Hole 5, etc."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Lots of well meaning help here if you want it. Not only accept the advice but use it to it's fullest potential. 1.2TLs, very nice place to start as far as SDA speakers go. With all that, yes the RDO-198 and go w/ this a first and easy drop in mod. Many,many threads on full upgrades all depending on your way of doing things and down to the simplest and least expensive way to go about it, Read on most member's sigs to see what was accomplished by each member usually over time.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
I followed the suggested recommendations and the results were spectacular. The guys on this forum will guide you right.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
