Model 10s -are they 6 ohm or 8 ohm & what to seal drivers in with
I've always been under the impression that Model 10s were 6 ohm speakers. However, I have seen some Polk literature saying they are 8 ohm and some Polk literature saying they are 6 ohm. The shop I bought them from always said they are 6 ohm, and the amplifier test clinics I've had the A-10 at always listed them as being 6 ohms.
Also, what is something good to seal the drivers in with?
I've got a replacement driver coming and that putty stuff that came on them is dried up & probably not doing a good job of sealing anymore.
Thanks!
  • Jimbo18
    Jimbo18 Posts: 2,351
    Most people on here recommend Armacell to replace the gaskets and it can be bought from Home Depot or ordered on line. Do a search on this site and you will see more than a few posts mentioning it.
    As far as how many ohm's your speakers are, I think it depends on the exact model. Do you know if they are Monitor 10a or 10b?
  • aprazer402
    aprazer402 Posts: 3,423
    The Polk Audio Series II Monitor line which came out around 1990 offered the Monitor 10 in a nominal 8 ohm version.
    mhardy6647 Posts: 35,308
    The original, unsuffixed Monitor Series Model 10 was specified by Polk as 6 ohm; I suspect that the 10A was also 6 ohm but I have no documentation to support that... and I have no idea about any later versions.
    The attached is from a brochure I picked up at Soundscape in Baltimore in 1977.
    11224549874_161b9577a0_b.jpgpolkca1976brochurebackpg by Mark Hardy, on Flickr
    I should make a higher-res scan of that ... one of these days...
  • coral191
    coral191 Posts: 17
    Mine are just plain Model 10 Monitors, bought new in 1977, before the A, B, etc models came out, but that probably explains why I've seen both ways in Polk lit.
    Not sure what Armacell is, but I'll google it and there is a Home depot not far from the house.
    Thanks!!!
    Definitely 6 ohm.
    They should look like this one (with an uncoated paper cone passive radiator):
    11208619575_674f036d9b_b.jpgP1020559 by Mark Hardy, on Flickr
  • aprazer402
    Here is a vintage Polk catalog prepared a few years ago by forum member "skrol".
    aprazer402 wrote: »
    Excellent; I don't think I've ever seen this before. Thanks for posting it to this thread.
    The family tree gets a little tangled up along the "Monitor 5" branch, doesn't it? :-P
  • coral191
    coral191 Posts: 17
    That picture looks exactly like mine, except my PRs are coated like the drivers. Everything else the same-brown faced baffle, thick greyish gaskets around the drivers, same tweeters, super Velcro attachment, 2 fuses on back.
    Turns out, I've got that same brochure, since I finally found my long-lost audio equipment folder just the other day. What was throwing me off seeing stuff on later models that are 8 ohms.
    edited July 2015
    ... which means, I reckon, that they (Polk) changed the drivers and/or they changed the crossovers.
    Do your Peerless tweeters have holes in the domes, or not? My "belief" is that very early Polk Monitor Series products didn't have the hole in the dome which later ones did.
    FWIW: my belief/understanding has always been that the coated PRs "appeared" on the "A" versions... but Polk was a very small company in those days & "continuous improvement" was probably ongoing -- and undocumented ;- )
    My Model 7s were sold to me as 7As -- and have two fuses, not just one, and coated 10" PRs. The original Model 7, though, actually had a smaller (8 inch) PR rather than the 10" PR (identical, I think, to the one used on the 10) of the 7A.
    edit: heh, as long as I am at it, I'll regurgitate a little more ephemera...
    The aforementioned brochure, which I think (?!?) may date from 1976 -- although I am sure I didn't pick up a copy 'til '77 -- shows an 8" PR on the 7.
    9606201717_d3fb6c6688_z.jpgearlypolkfamilyportrait by Mark Hardy, on Flickr
    A somewhat newer ('78, I think) catalog from Gordon Miller Music (also a Baltimore company) shows, on two different pages, a "Polk 7A" with an 8" uncoated PR (i.e., a Model 7) and a system with a "Polk Model 7" with the 10" uncoated PR. Copy editing was a little more laborious in those days :-P
    14742055264_6f038a8c48_b.jpgGMMspeakerpage by Mark Hardy, on Flickr
    11324607964_fc5f4a9661_b.jpgwhatmore by Mark Hardy, on Flickr
  • leftwinger57
    leftwinger57 Posts: 2,917
    I used as mentioned before Armacell-Armaflex ap insulation tape as you see in the pix on the left it's on a roll and you can do many,many speakers. It compresses real tight used in conjunction w/ Larry's rings which may or may not be still available.Tool compizdqjiuz695ls.jpg
    lation was for total modding of my 2Bs
  • leftwinger57
    Forgot to mention ,Mark you said that Polk did not always sticky coat their speakers back in the day. My 7s w/ the Peerless tweeters and out board fuse holder are not coated. I just thought they were sun bleached but not discolored and I'm going w/ your assumption.
  • vmaxer
    vmaxer Posts: 5,121
    aprazer402 wrote: »
    Very cool.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • coral191
    coral191 Posts: 17
    My soft dome tweeters do have the little hole in the middle, and they have nothing stamped on the backs, which I think means they are Danish ones.
    Are those still the best tweeters to have?
    there is debate -- but I like 'em :- )
  • tonyp063
    tonyp063 Posts: 1,142
    "Best" is relative & an opinion.
    I have both monitor 7s & 10s (crossovers rebuilt) with the Peerless tweeters & I love the way they sound.
    My brother has a pair of 7s with RDO-194s ( also rebuilt) and I also love the way the way *they* sound.
    Very discernibly different, but both very good.
  • leftwinger57
    Tony, your right it's all subjective to the listener. I changed out the silver domes to RDO-194s in my 2Bs and it was like night and day.The 28 y/o tweeters compared to the 194s well there is none. The Peerless of the 7s w/ somewhat of a softer tone will stay.
  • coral191
    coral191 Posts: 17
    IF..one of my Peerless tweeters went bad, is the RDO-194s gonna be the best (new)replacemenst available?
    edited July 2015
    you'd have to change both tweeters and there might be (I am not at all expert on this topic!) crossover alterations required, too.
    Peerless made those tweeters for decades (into the early 1990s, at least); used ones aren't too hard to find.
    There is also a current production, 'brand X' replacement available, as well.
    https://www.midwestspeakerrepair.com/mw-audio-mt-4115-1-inch-dome-tweeter
    I've never heard one, though, and they're certainly not cheap. Again, if I went that route, I'd think it would be best to replace both.
  • tonyp063
    IF..one of my Peerless tweeters went bad, is the RDO-194s gonna be the best (new)replacement available?
    Significant crossover modification AND cabinet modification. The RDO-194 is not a drop-in replacement for the Peerless. Different fitment.
  • coral191
    coral191 Posts: 17
    Thanks for info everyone!! Its good to know my options should something quit
