Any banana plug recommendations for SDA 2B TL speakers?
pglbook
pglbook Posts: 2,262
edited July 2015 in 2 Channel Audio
Can anyone recommend good banana plugs for my Polk SDA 2B TL speakers?
I currently have bare speaker wire around the binding posts and want to get banana plugs because I recently had an issue with the speaker wires on the left speaker becoming loose and that speaker losing sound. I tightened the wires and all was fine but the same thing happened about a week later - low sound from left speaker, I retightened speaker wire on binding post and problem solved again. That makes me think the speaker wire is becoming loose on that speaker (right speaker never has had that problem) and banana plugs are the way to get a better connection.
Any suggestions?
Thanks.
  • pearsall001
    pearsall001 Posts: 5,295
    pglbook wrote: »
    Any suggestions?
    Thanks.
    Excellent 'nanners...been using them for years.
    http://www.speakerrepair.com/page/category/locking.html
  • PolkieMan
    PolkieMan Posts: 2,446
  • Mikey081057
    Mikey081057 Posts: 7,127
    These are easy and cheap and take some of the stress off of the wire as the bare wire goes thru at a 90 degree angle
    http://www.amazon.com/AmazonBasics-Gold-Connector-Banana-Plugs/dp/B0090CVJZ4
    Garage | Polk Monitor 5B's
    EndersShadow Posts: 17,705
    Personally, I'd spend a "little" bit and get Kimber Kable SBAN connectors (short for Standard Banana). Otherwise Audioquest terminations are quite nice. However both are going to run you more than the GLS and Monoprice connections.
    If you want to go with the GLS, I'd suggest the non locking banana's. I had them (might still have some lying around) and just didnt like the way they worked. The standard Black Chrome type work ok for me.
    http://www.amazon.com/GLS-Audio-Chrome-Generation-Connector/dp/B000QIZXHG
    I use some similar Monster Cable quick release banana's for my LSi f/x as I havent upgraded the speaker wire there just yet.
  • drumminman
    drumminman Posts: 3,396
    A great reasonably priced nanner can be bought from our own helipilotdoug aka Douglas Connections. I replaced high quality brass nanners with these and was shocked at the improvement:
    http://www.douglasconnection.com/Furez-TSTSB40Ag-Silver-Plated-Copper-Banana-Plug-Connectors-Pair-FZTSTSB40Ag.htm
    Brass is not a very good conductor, and the above are made of silver plated telurium copper. Makes a difference. They also have unplated copper for a few dollars less.
  • vmaxer
    vmaxer Posts: 5,120
    drumminman wrote: »
    This is your huckleberry.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • voltz
    voltz Posts: 5,384
    Hey Pete!
    I have used almost all that has been mentioned here, the GLS's are nice...as are the AQ that AB mentioned and they are still in use for my long run of cables to my 2 rear surrounds.
    I also made a backup set of Furez I got from Doug along with the nanners drumminman gave a link for, and if you add some shrink wrap to them they come out really nice, i also use some cable splitters I got from Doug also and add some sleeves.
