Any banana plug recommendations for SDA 2B TL speakers?
pglbook
Can anyone recommend good banana plugs for my Polk SDA 2B TL speakers?
I currently have bare speaker wire around the binding posts and want to get banana plugs because I recently had an issue with the speaker wires on the left speaker becoming loose and that speaker losing sound. I tightened the wires and all was fine but the same thing happened about a week later - low sound from left speaker, I retightened speaker wire on binding post and problem solved again. That makes me think the speaker wire is becoming loose on that speaker (right speaker never has had that problem) and banana plugs are the way to get a better connection.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
Excellent 'nanners...been using them for years.
http://www.speakerrepair.com/page/category/locking.html
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
These are easy and cheap and take some of the stress off of the wire as the bare wire goes thru at a 90 degree angle
http://www.amazon.com/AmazonBasics-Gold-Connector-Banana-Plugs/dp/B0090CVJZ4My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Personally, I'd spend a "little" bit and get Kimber Kable SBAN connectors (short for Standard Banana). Otherwise Audioquest terminations are quite nice. However both are going to run you more than the GLS and Monoprice connections.
If you want to go with the GLS, I'd suggest the non locking banana's. I had them (might still have some lying around) and just didnt like the way they worked. The standard Black Chrome type work ok for me.
http://www.amazon.com/GLS-Audio-Chrome-Generation-Connector/dp/B000QIZXHG
I use some similar Monster Cable quick release banana's for my LSi f/x as I havent upgraded the speaker wire there just yet."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
A great reasonably priced nanner can be bought from our own helipilotdoug aka Douglas Connections. I replaced high quality brass nanners with these and was shocked at the improvement:
http://www.douglasconnection.com/Furez-TSTSB40Ag-Silver-Plated-Copper-Banana-Plug-Connectors-Pair-FZTSTSB40Ag.htm
Brass is not a very good conductor, and the above are made of silver plated telurium copper. Makes a difference. They also have unplated copper for a few dollars less."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
All copper, I have been thinking of trying these http://smile.amazon.com/gp/product/B00TQ1FOKA?psc=1&redirect=true&ref_=ox_sc_sfl_title_10&smid=ATBKBUXFLDT1Y
drumminman wrote: »A great reasonably priced nanner can be bought from our own helipilotdoug aka Douglas Connections. I replaced high quality brass nanners with these and was shocked at the improvement:
This is your huckleberry.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Hey Pete!
I have used almost all that has been mentioned here, the GLS's are nice...as are the AQ that AB mentioned and they are still in use for my long run of cables to my 2 rear surrounds.
I also made a backup set of Furez I got from Doug along with the nanners drumminman gave a link for, and if you add some shrink wrap to them they come out really nice, i also use some cable splitters I got from Doug also and add some sleeves.
