I may be on to something here with the magic erasers???
  • pumpkinman
    pumpkinman Posts: 10,198
    afterburnt wrote: »
    What is that, an electric cork?
    Vibration isolation blocks. I'll find a link and post it here.
    Because I am The Pumpkinking
  • soundfreak1
    soundfreak1 Posts: 3,414
    I bought a box of these some years ago, box of 48 paid like 12.00 in bulk just woundered if anyone else used them and what they thought.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • soundfreak1
    Oh the electric cord... it recharges them.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    LOL
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • pumpkinman
  • soundfreak1
    Yep that where i got mine
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • afterburnt
    afterburnt Posts: 7,892
    Pretty slick, reasonably priced maybe I will get some for my sneakers!
  • soundfreak1
    Not sure how good they are but at that price i had to try.them. they are used for anti vibration on machinery so what the he..
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • pumpkinman
    A lot of guys use them and are quite happy. They sell them on audio sites for like $4 a piece. LOL
  • soundfreak1
    Yep, i figured at .25 cents each wtf.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • boston1450
    boston1450 Posts: 7,758
    They also sell platforms & sand boxes that can help. http://www.brightstaraudio.com/Store.html .... There are alot of sites out there
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • soundfreak1
    A tad bit more than .25 cents.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    I built this sand box for mine and it helps quite a bit. My floor is setting directly above a steel I beam so it has a bit of spring to it, and wreaks havoc on the turntable. The sandbox didn't solve the problem completely, I can at least walk in the room now.
  • soundfreak1
    That box looks beautiful, do you have any picts with the top off. Just wanted to see ynder the hood. Never seen how a sand box is put together.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
