I may be on to something here with the magic erasers???
afterburnt
in Electronics
I am blasting 2112 and checking the vibration coming up through the shelf from the floor to the TT. The magic erasers that I set the TT legs on have seriously reduced the vibration reaching the TT much more so than the vibrapods alone. I may eliminate the vibrapods and replace them with more magic erasers or add a second platform in between. The vibrapod set that I have is probably overloaded with the TT and the platform anyway. I don't care how it looks I only care how it works.
The dust cover on the TT does vibrate quite a bit still but that is just from the sound not from the floor. Any suggestion on how to dampen that? I keep it closed because I live in the dustiest place on earth.
Man you want me to figure out how to put a pic up?
I use this butcher block & i can jump up n down & no issues
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Well
boston1450 wrote: »I use this butcher block & i can jump up n down & no issues
Great idea, solid, heavy, shock absorbing!
Nice Yammie CR-1000 there!
"And (letmeh tellyoo) it looks (and sounds) mahvelous...absolutely mahvelous!"
I cant make the pic upload but pretty much like cnh's pic. Top shelf-vibrapods-platform-erasers-TT. The platform is a shelf out of an old entertainment center, I have another that I can use. So I will try erasers-platform-vibrapods-platform-erasers-TT. What the heck more erasers are like 3 bucks.
cnh, you got anything between the butcher block and the TT or shelf top?boston1450 wrote: »I use this butcher block & i can jump up n down & no issues
afterburnt wrote: »
It's Randy (Boston1450) with the TT on the butcher block, NOT cnh.
Sorry Randy. So are you using anything for vibration between the TT?
My only concern here is will it maintain level. If one corner weighs more will Magic Eraser keeps the same thickness or will it compress ?? I'm betting it will compress even if it's just a little.
P-man
Because I am The Pumpkinking
That is my Technics sl1300 with a butcher block i cut out of a old countertop/roll away cart. I was gonna burn it & read here to try/buy butcher block for isolation & it does work for me.Randy-Maine
by David WMG
Good point Bill. I dont think that will be and issue if I use the magic erasers between the top and platforms because the load is spread over a lot of surface area. Each eraser is about 3x5. However the TT is still checking level for now sitting directly on the erasers. I am trying to keep the vibrapods in the mix only because I paid 25 bucks for them.
I would start with a decent sturdy rack/shelf. If its flimsy thats not good-in my book & im no expert in turntables. But i use to walk around on pins n needles. Not no moreRandy-Maine
by David WMG
[/quote]
[/quote] ...... Nothing. Sturdy rack-glasstop with block just sitting on it. I was going to put little rubber thingy's on it & didnt need to. I did this 8 months ago with great results with ZERO budget i had to work with
Randy-Maine
by David WMG
This is what it is on, it's fairly solid.
http://www.amazon.com/Sanus-Systems-AFA-Accurate-Furniture/dp/B00004U8A0/ref=sr_1_4?ie=UTF8&qid=1436888582&sr=8-4&keywords=sanus+shelf -
That looks nice. i would try a butcher block. Look for used on Clist. Cut one out like i did/look online under turntable. Just a thoughtRandy-Maine
by David WMG
Im got good with turntables. But are the feet on tt decent ? They also have upgraded ones i would think that may be worth a lookRandy-Maine
by David WMG
I do have a 1.75" thick butcher block that I hardly use. I will try it. Thanks
Damn, I may have to use those magic erasers to scrub the tub now %^(
The feet look like they are decent one, I will check it out.boston1450 wrote: »Im got good with turntables. But are the feet on tt decent ? They also have upgraded ones i would think that may be worth a look
Randy Do you use anything under the butcher block and can you feel any vibration coming through it?boston1450 wrote: »That looks nice. i would try a butcher block. Look for used on Clist. Cut one out like i did/look online under turntable. Just a thought
Nothing. I just laid it down in place & put the turntable on it.... I wondered if i should. But i never did 8 mos ago & dont intend on it now. You could try & see. Maybe read what others have done as im no expertRandy-Maine
by David WMG
I will try it when I get home but I suspect that it will transmit the vibration since my floor acts like a big drum head. I will probably end up with some crazy looking sandwich of stuff.
Like i stated before. I use to walk in living room & it would cause problems with tt & i did some asking around here & i tried this & it worked for me. Not hi end & not new expensive top of the line gear. But a skill saw & sand paper machine & stain walla im happy & it did wondersRandy-Maine
by David WMG
I will use it if nothing else it should resonate less than the shelves
Have you thought about the wall mount rig-ma-doRandy-Maine
by David WMG
No room
Anyone ever use these?
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Yes I bought a entire box from pexsuppy.com
What is that, an electric cork?
