sda-srs 2.3
Hello. Looking at buying a pair of sds-sra 2.3, used for 500 dollars in good shape.
Questions: do I need to buy the cable from speaker to speaker?
can I replace the grill on the sides and front ?
my amps are Sony TA-55ES/300 watts in mono; will two amps be able to power those Giants?
any other tips is/are greatly appreciated.
Regards.
    F1nut Posts: 51,977
    For the SDA to work you need the cable.
    Yes, you can replace the cloth.
    You cannot use non-common ground or mono blocks with those speakers unless you use the AI-1 SDA cable.
  • quadzilla
    quadzilla Posts: 1,543
    For amps running in mono, you need the AI-1 cable, just just a regular SDA cable.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
