sda-srs 2.3
beru
Hello. Looking at buying a pair of sds-sra 2.3, used for 500 dollars in good shape.
Questions: do I need to buy the cable from speaker to speaker?
can I replace the grill on the sides and front ?
my amps are Sony TA-55ES/300 watts in mono; will two amps be able to power those Giants?
any other tips is/are greatly appreciated.
Regards.
Regards.
For the SDA to work you need the cable.
Yes, you can replace the cloth.
You cannot use non-common ground or mono blocks with those speakers unless you use the AI-1 SDA cable.Political Correctness'.........defined
President of Club Polk -
For amps running in mono, you need the AI-1 cable, just just a regular SDA cable.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
