Just in case anyone cares: Furez 12 AWG 2 Conductor
I had to do some testing with some OFC "zip cord" to get things together. Well compared to the Furez 12 AWG 2 Conductor from Douglas Connection raw wire there is a striking difference. It was sad to say the least. No question, I am gonna redo the bedroom with the Furez, it made that much of a difference. I am still using the same mediocre bananas.
  • afterburnt
    afterburnt Posts: 7,892
    It is a PITA but it's worth it. RX-A1040 and XPA-3 is going there. No point with crappy wires.
  • mrloren
    mrloren Posts: 2,487
    edited July 2015
    I like my Furez 10AWG on my HT setup. I am not using that good AV stuff you are but it made a big difference from the MonoPrice cable I had.
