Surround Bar with a DSW Pro Wireless Sub?
nikolas812
Will one of your DSW wireless subs sync up with my Surround Bar 5000?
Nik
Nik
Hello,
Check with Polk's CS guys at 1-800-377-7655 for best information source.
Regards, Ken -
Apparently it won't work. You have to use the sub that comes with the sound bar.
Nik -
hi, do you know if i can put SB5000 to factory defaul?. i see a 6 pin conector for Factory process at rear if bar. thank's
