Used Dreadnaught Case FS With Dynamat
GlennDog
Let this be a lesson when shipping trannies. Block/brace the tranny, just in case the bolt comes loose. The bolt is only supposed to be tightened a smidgen past finger tight. That's Not gonna cut the mustard when shipping X-country. I'd recommend Lock-Tite on the threads, too!
So that's what happened and the washer scrapped the paint off. The Dynamat got a little fudged-up as well. Not sure WTF happened to the Bottom Rear corner.
Being very critical, I'd rate this a 7/10. Some might say a solid 8 or 9 as the blemishes are not visible when the case is set-up in listening position. The imperfection at the Bottom Left Rear Corner cannot be easily seen. Many of these are mounted behind all the electronics and the entire case is not visible.
IIRC, new cases go for approx $100 and no Dynamat . . . I'd like to see $65 clams
Thanks for looking!
Shipping damage caused the issues that you see below
Thanks for looking!
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12
I though selling trannies across state lines was a federal offense...
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
PM incomingVA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Which tranny did this have in it?
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
1K VA
Btw, all Avel AI-1 transformers will/should fit inside this case
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
They will hold both the 800 and 1k VA..
fyi, Doug has the good/great Cardas binding posts on sale. I do not know how long the sale lasts.
Someone could put together a AI-1 for not allotta dough
http://douglasconnection.com/SPECIALS_c39.htmAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Mark this bad boy SOLD!AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12
