Used Dreadnaught Case FS With Dynamat
Let this be a lesson when shipping trannies. Block/brace the tranny, just in case the bolt comes loose. The bolt is only supposed to be tightened a smidgen past finger tight. That's Not gonna cut the mustard when shipping X-country. I'd recommend Lock-Tite on the threads, too!
So that's what happened and the washer scrapped the paint off. The Dynamat got a little fudged-up as well. Not sure WTF happened to the Bottom Rear corner.
Being very critical, I'd rate this a 7/10. Some might say a solid 8 or 9 as the blemishes are not visible when the case is set-up in listening position. The imperfection at the Bottom Left Rear Corner cannot be easily seen. Many of these are mounted behind all the electronics and the entire case is not visible.
IIRC, new cases go for approx $100 and no Dynamat . . . I'd like to see $65 clams
Thanks for looking!
Shipping damage caused the issues that you see below
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
    EndersShadow Posts: 17,704
    I though selling trannies across state lines was a federal offense...
    :wink:
  • MrBuhl
    MrBuhl Posts: 2,419
    PM incoming
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • headrott
    headrott Posts: 5,496
    edited July 2015
    Which tranny did this have in it?
  • GlennDog
    GlennDog Posts: 3,152
    edited July 2015
    headrott wrote: »
    1K VA
    Btw, all Avel AI-1 transformers will/should fit inside this case
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    Toolfan66 Posts: 18,055
    They will hold both the 800 and 1k VA..
  • GlennDog
    fyi, Doug has the good/great Cardas binding posts on sale. I do not know how long the sale lasts.
    Someone could put together a AI-1 for not allotta dough
    http://douglasconnection.com/SPECIALS_c39.htm
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • GlennDog
    Mark this bad boy SOLD!
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
