Replaced Polyswitches
ISLANDREAMER
F1 Nut,
I got the 4 polyswitches from Ken Swauger (Polk Tech Support) and did replace all four but only one baffle works. The Dimensional H.F. on the other is still not sounding.
Would it hurt anything if I parallel this H.F. unit to the Stereo H.F. on my SDA-2?
Post edited by ISLANDREAMER on
Bad idea.
Have you swapped the tweeters around? Checked the wiring in the cabinet?Political Correctness'.........defined
President of Club Polk -
Thanks for the tip F1 nut. I switched the tweeters around and both tweeters work. I also did check the wiring. I am suspecting the crossover needs an expert look. Do you know if Polk Audio will work on these old SDA-2 crossovers for a fee?
Let's keep this discussion in one place, eh?
Ok, you should contact Ken Swauger again.Political Correctness'.........defined
My bad. I'll shoot Ken an email. Thanks.:D
