LP to FLAC software
The new TT with USB will be here in a couple of days and I want to wash play and rip my albums as I go. Anyone suggest a moron proof software package that will accomplish this?
  • vcwatkins
    vcwatkins Posts: 1,992
    Vinyl Studio is straightforward to use. I get the impression most folks use a separate declicker, but I just use the one in VS.
    Here's a PS Audio video on setting up VS.
  • afterburnt
    afterburnt Posts: 7,892
    what's a "declicker"?
  • vcwatkins
    Program to minimize pops and clicks in the digitized flac files.
  • bmor
    bmor Posts: 44
    Just curious, how well do these programs work?
    2 CH - SB Touch, CA 840C, CA 840Av2, PSB Imagine T
    HT - Pioneer 1325, Emo UPA-1, MA Silver RS series 7.1
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    Which TT did you decide on?
  • afterburnt
    TEAC TN-300 Analog Turntable with Built-in Phono Pre-amplifier & USB Digital Output because it looks pretty lol
  • bmor
    bmor Posts: 44
    Keiko, does the software completely eliminate all surface noise?
  • jeremymarcinko
    That is a pretty one for sure. I bet it sounds great too.
  • vcwatkins
    bmor wrote: »
    Works pretty well. I use very sparingly, only running the routine if the lp is in bad shape - don't want to give up any detail or dynamics. I like the VS one because it's an easy step to add while in the same program.
