Score! Are these 4 or 4.5?
I knew I had joined up for a reason. It took a while to find a pair, but I finally did and just look at them! One of the woofers is dead, but luckily they still have a bunch of new ones in stock. So for $19.99 and the price of the new woof, they will be singing once again very soon. I'm just not sure if they are 4 or 4.5 models. I get conflicting info one saying 4 was sealed and 4.5 ported, then others saying both were ported and it depends on the tweeter. Build date is 1990. I can't believe they survived GW in such intact shape!
  • mannye
    mannye Posts: 15
    Never mind! Serial number starts with M4 so they must be M4. Very cool. The one that works sounds much nicer than I thought. Can't wait to hear them together.
  • vmaxer
    vmaxer Posts: 5,120
    Congratulations on the find!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Nightfall
    Nightfall Posts: 10,083
    I want to say all Monitor 4's are ported.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • mannye
    mannye Posts: 15
    After cleaning them up and getting a look inside I'm worried I may now be spending a lot of time trolling for. Vintage PolK. This is looking bad because these little guys are so surprisingly good! :smile:
  • boston1450
    boston1450 Posts: 7,758
    Dont hesitate to get those up n running. I have a pair of 4's series2's & they are a great speaker. Polk stocks the driver & if you ever need a tweeter they are available on the bay cheap.... They will last years if properly used
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    If you go through Polk. Call & tell them your a forum member & get a great discount. Welcome to the forum. Stick around & enjoy your Polks & dont hesitate to bs about other things. Great bunch of guys/gals here
    Randy-Maine
    by David WMG
  • mannye
    mannye Posts: 15
    I found a used one on the Bay. I may still get two new ones, but first I'm going to address the caps on the crossovers. Anyone know if there's a source for "real" connectors? Those spring loaded things are killing me, not to mention one of them has the little plastic clips missing. And some idiot (looks around with a guilty countenance) kind of broke the other one when he was removing the bad woofer...when I catch that guy.... I tell ya.... :|
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    I just redid a pair of Monitor 4 Series II and they are *much* better after swapping out those tiny electrolytic caps and double stacked 2ohm cermet resistors. I hate those spring clips too, so I swapped them out for these from Parts Express:
    Round Speaker Terminal Cup 2-7/8" Gold Banana Binding Post
    Part # 260-283
    Don't let the fact that they are round instead of square deter you. They fit the 2" diameter hole cut in the cabinet perfectly and the screw holes even line up. Replacement couldn't be easier. You will have a problem with the fact that the XO board was soldered right to the spring clips. I decided to go with new components all around from Parts Express (a close-enough inductor was even in stock) and wired them up point-to-point.
    I'll attach pics of the old and new, so you can double check to see if we're talking about the same animals.
  • mannye
    mannye Posts: 15
    Thank you for the help! If I can desolder everything cleanly from the original board I will hot glue it somewhere in the cabinet. If not, it seems easy enough to do the point to point thing. I built a pair of Bottlehead Paramours and a Foreplay so a little point to point is no big deal,. Thanks for the pics too!
  • On3s&Z3r0s
    No problem. The XO's are very simple as you can see so point to point is easy if you end up going that route. The original schematics are here on the site in the non-SDA sticky by dorokusai, and I could scan in a drawing I made to help me lay it out if you decide to do that. The hot glue thing would surely work, and the point to point board pictured above was actually mounted first with just industrial Velcro. That stuff'll pretty much hold anything, but I added the screw out of an abundance of caution to keep the board from vibrating at all.
    The Jantzen inductor doesn't sound bad, but if anything the speakers now sound overly tubby in the bass. If I had it to do over again I'd keep the stock inductor. The caps and crappy resistors definitely should get replaced though. I was surprised at how much different the tweeters sounded after. Have fun!
  • mannye
    mannye Posts: 15
    I just noticed you used the 5.6 value vs the original 5.8 MFD which is proving to be a difficult value to find. Is this what most people are using? The much more expensive audiophile caps can be had in the exact value but I'm not sure if I want to spring for the cash. I guess if you are happy with the sound, I can give it a shot too.
  • On3s&Z3r0s
    edited July 2015
    Most people feel that 5.6 is close enough since it's within the +/- 10% spec'd. (It's only about 3% off.) I've used both 5.6 and 6.0 in different speakers in place of the 5.8's before Sonic Craft started keeping that value in stock. I've found that I like the 5.6's better than 6.0, and it seems to be the value most people use if they're not using Sonics. I've even seen folks go with 5.6 on other higher end caps like Clarity when the 5.8 value isn't available. In the case of my Monitor 4 S2's all I can say is they sound noticeably better with the Dayton poly caps than the original tiny electro caps. For this application I wouldn't hesitate to recommend the 5.6 caps.
  • mannye
    mannye Posts: 15
    This forum is AWESOME. Thank you for the info! The parts are actually here now. I'll do a little photo essay once I start.
