The Polk bug strikes again!
dharding
dharding Posts: 61
edited September 2004 in Speakers
deleted
Post edited by dharding on
  • nadams
    nadams Posts: 5,877
    edited August 2004
    daaaaaamn youuuuuu!!!! :p
    Oh well, I'm still happy with my Monitor 10's
    Ludicrous gibs!
  • dharding
    dharding Posts: 61
    edited August 2004
  • Emlyn
    Emlyn Posts: 4,708
    edited August 2004
    Originally posted by dharding
    Looking at various pictures online, the speakers I bought yesterday look much closer to 2As than 2Bs (My 2Bs have wooden top and bottom plates (oak?), whereas these are just cabinets in black)
    How does one tell the difference between 2A and 2B, and what are the spec differences?
    OT comment: I *really* wish the minimum search term length here was 2 characters instead of 3. That way you could search on 2A, 2B, 1C, etc. It would make things a lot easier...
    Thanks,
    -Dan
    Dan, sounds like you got the 2B Studio version in the black ash vinyl. The easiest way to tell for sure seems to be to pull one of the mid-woofers to see what number it is. 2As used the MW6510 exclusively. 2Bs used MW6503 and MW6511 drivers. The 2Bs were rated as 6 ohm, the 2As as 5 ohm. Most 2Bs seem to have the pin/blade interconnect. My 2Bs have the twin blade interconnect though. I have a pair of the 2As and 2Bs and can't tell any sonic differences. There seemed to be some cabinet sharing going on during the transition from the 2A to 2B versions.
    Agreed on the two character search option.
  • dharding
    dharding Posts: 61
