SACD? I got some cheap ones
But I don't think they are SACD how can I tell, oppo says: CDDA 44.1K 16b?
  • aprazer402
    aprazer402 Posts: 3,401
    They should all be marked on the case and on the disc. Some good info. here: http://www.ps3sacd.com/sacdfaq.html
    F1nut Posts: 51,959
    CDDA 44.1K 16b?
    That is a regular CD.
  • aprazer402
    Sorry I can't be of more help. I have SA-CD players, but not an OPPO. Mine identify sa-cd's if on a DVD universal player or a dedicated SA-CD player. Maybe an OPPO owner will respond.
  • afterburnt
    afterburnt Posts: 7,892
    CDDA 44.1K 16b?
    thanks that's what I thought. Amazon.com listed them as hybrids
  • afterburnt
    aprazer402 wrote: »
    The oppo clearly say SACD on the floyd and yellow jackets cd's
    F1nut Posts: 51,959
    afterburnt wrote: »
    A common problem with the sellers on Amazon from what I've read. Whether they misrepresent on purpose or not I don't know. Try eBay for used or OOP titles, otherwise places like Music Direct or Acoustic Sounds have a good selection of in print titles.
  • hochpt21
    hochpt21 Posts: 5,423
    afterburnt wrote: »
    CDDA 44.1K 16b?
    If they are hybrids...maybe your playback settings aren't correct and it is playing the regular cd layer??
  • hochpt21
    Which Oppo do you have?
  • afterburnt
    Yeah not such a big deal they were like ten bucks average
  • afterburnt
    hochpt21 wrote: »
    I have a 103d 2 of the disc display sacd info and 2 don't
  • Erik Tracy
    Erik Tracy Posts: 4,673
    Did you check the case and the actual disc for the DSD logo?
  • afterburnt
    No indication on disc or case. I will call Amazon
  • afterburnt
    Amazon says the the market place seller puts their stock in the Amazon warehouse. Amazon only knows what the seller newbury_comics tells them. They are letting me return them. I will not be using that seller again.
    F1nut Posts: 51,959
    Right, unless something is stocked and sold by Amazon, it's the seller's responsibility for the listing with Amazon acting as the distributor. You are not the first I've seen complain about Newbury Comics sending a CD instead of an SACD.
  • afterburnt
    At least the two that I was most interested in were actually SACD's
    F1nut Posts: 51,959
    afterburnt, here's a good site for all that is SACD.
    http://www.sa-cd.net/home
  • afterburnt
    Cool thanks F1
