I think my SDAs just died.....
  • Polkie2009
    Polkie2009 Posts: 3,834
    +1 sorry to see you're having these problems Polkieman and BlueBirdMusic. Drumminman, how have you avoided hear problems over the years? A number of drummers I used to work with all started having hearing problems around their late 30's. Most had been playing rock drums regularly for over 20 years by then. I think the lead guitarists always started have hearing issues in their twenties. Always reaching for that volume control to play over the drummer. I'm sure you know how that scenario runs.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,765
    Polkie2009, I spent more time for about 20-25 years on two other hobbies - sailing and golf thus avoiding much loud music.
    I didn't listen to as much music as I did when my SDA 2B's were purchased new. The 2B's made a trip to the other side of Atlanta while I was in Myrtle Beach playing golf about 15 years ago. The wife moved out with them which is ironic since she really did not like them (size) when originally purchased.
    Four or five years ago, my SDA obsession surfaced again, and I purchased 1A's followed by 1B's from Craigslist. I started going to live concerts again, and the rest is history.
    You mentioned drummers and I thought of the fantastic drummer in Forgerty's band who really was showcased. LOUD! The ENT told me going to the live concerts would continue to affect my hearing. He suggested I wear the same type of ear plugs that are used on gun ranges. I have read that some meds can cause the tinnitus to occur.
    Last year, I discussed upgrading my 2B's with westmassguy. Per his advice, I replaced the tweeters with the RD0194's (great improvement), but I am struggling making a decision with the caps, etc, because of the hearing loss.
    Life goes on!
    Harry Jones
    Marietta GA
    Harry / Marietta GA
  • drumminman
    drumminman Posts: 3,396
    Polkie2009, I may be just lucky. The loudest band I was in was a 3 piece blues band, and I always wore hearing protection. The group I play with now isn't that loud.
    BlueBird, I suggest doing the upgrades. The new high quality caps/resistors/inductors will make improvements across the frequency range (not just highs), and probably improve imaging as well.
  • PolkieMan
    PolkieMan Posts: 2,446
    My hearing problems have come from working in Machine shops for 40 years and probably just age in general.
    F1nut Posts: 51,738
    If you could hear the improvement from the tweeters, you will absolutely hear the improvement from the crossover upgrades.
    heiney9 Posts: 25,430
    Make sure whatever amp you are considering, it's a common ground amp.
    tonyb Posts: 33,072
    PolkieMan wrote: »
    Doubt it....betcha it's from being married for just as long.
  • I'm with F1 new caps and resistors make a huge improvement, well worth the effort and coin IMHO
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
