$600 to $800 receiver for RTi A4 / CSi A4
Hi
I'm about to upgrade my relatively basic receiver (Pioneer VSX920)
I've heard Audyssey MultiEq XT32 is very good....So looking at receivers with that feature, I've found on A4L the Onkyo TX-NR818 or the Marantz SR7008
The Marantz is more expensive ($750 vs $580)
The Marantz weight 27Lbs when the Onkyo is at 40Lbs. About watts, the Marantz is given at 125W and the Onkyo at 135W
What would be the best pick to match with my Polk speakers?
RTiA5 + CSiA4 + Jamo SW410E
Yamaha TSR-700 (equivalent to RX V6A)
No surround...yet
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    The Onkyo 818 is an excellent value. After that model Onkyo started removing features and weight from the 8xx series.
  • DollarDave
    DollarDave Posts: 2,575
    I grabbed a denon avr-x4100w from accessories4less.com for $799. I love the xt32 version of Audyssey! I happen to run a separate amp, but I didn't when I initially set it up and it sounded great.
  • French_guy
    French_guy Posts: 338
    Yeah, The Onkyo seems to be a lot of AVR for the money
    I like the look of the marantz though, but I'm not sure it's worth the price difference...
    No surround...yet
  • mrloren
    mrloren Posts: 2,474
    edited June 2015
    cant go wrong with either. if it was me making the buy I would get the Onkyo and add the Onkyo BD player. http://www.accessories4less.com/make-a-store/item/onkbdsp809/onkyo-bd-sp809-thx-certified-blu-ray-disc-player/1.html
  • WLDock
    WLDock Posts: 3,073
    I send you a PM.
  • French_guy
    mrloren wrote: »
    Is that BD player real good?
    No surround...yet
  • French_guy
    I was searching "TX-NR818 vs Marantz 7008", and found other references as well, such as Denon X4000 and 4520CI, Yamaha RX A2030, RX A3010, RX A2020, etc...All in the same price range at A4L
    Any one much better than the others? Any specific one recommended (or not recommended) for RTi A5?
    No surround...yet
    tonyb Posts: 33,072
    Anyone of the mentioned will be perfectly fine driving the RTI5's. Just a matter of the bells and whistles you want....or don't want.
  • jeremymarcinko
    I agree with Tony those all are fine units.
  • mrloren
    French_guy wrote: »
    mrloren wrote: »
    Yes there are a lot of good reviews on it. It is not your off the BB shelf throw away BD player
  • kevhed72
    kevhed72 Posts: 5,140
    edited June 2015
    If you can do without HDMI, you will find a low cost Onkyo in the For Sale section here....shameless plug
  • French_guy
    I need HDMI, and also up-scaling from component to HDMI (for my daughter's Wii and PS2)
    I will run 5.1, maybe add some "height" speakers if it makes sense
    Not sure I will go 7.1 (not soon at least because of my room)
    And I really want the Audyssey MultiEq32, I've heard it was really good
    So basically, I'm looking for the "best bang for the buck" AVR....
    Ultimate thing that would be a HUGE plus: a receiver that could run on 110V and 220V
    But I think it's going to be hard to find...!!!
    No surround...yet
  • WLDock
    WLDock Posts: 3,073
    edited June 2015
    Like speakers and other audio equip...the one for you is a matter of subjective opinion. Modern tech, design, and, manufacturing has produced a marketplace full of competent affordable products... with tons of features. One really has to try different products to see which one is liked the best. Sometimes it can come down to the small differences that will influence the decision.
    The RTi's have a pronounced sound with good efficiency and an easy load so most anything decent can drive them. However, once you get a full surround system connected an amp is always recommended to get the impact and clarity at near reference levels.
    Don't rule out used as some good deals can be had. My unit that I PM'ed you about is a serious unit (even today).
    http://www.onkyousa.com/Products/model.php?m=TX-NR3008&class=Receiver
    Here is another nice used unit.
    http://denver.craigslist.org/ele/5083832661.html
    Find something used for $300-$500 you might even be able to find a 2-5 ch amp within your ~$800 budget.
    http://jacksonville.craigslist.org/msg/5017572196.html
    https://losangeles.craigslist.org/sfv/ele/5081343157.html
    http://www.ebay.com/itm/Parasound-2125-Two-Channel-THX-Amplifier-/111700681516?pt=LH_DefaultDomain_0&hash=item1a01e1232c
    Post edited by WLDock on
  • kevhed72
    I agree with the above post....try to swing a separate 5 channel with an AVR that will do the job. I never use most of the features on my Pioneer AVR. Unless you have a very large, dedicated HT room, I would not worry about 7.1 or height speakers....but thats just one opinion.
  • French_guy
    Should i consider an Atmos receiver or not?
    No surround...yet
  • Erik Tracy
    Erik Tracy Posts: 4,673
    I'd go to a theater that has Dolby Atmos and watch a movie first to get a feel for the experience to decide whether it is enough of an impact for you to want it.
    Then you'll have to figure out if you have the space and layout to accommodate the 7 speakers, get an atmos capable avr, and then wait for enough titles to come out to make it worth it.
  • WLDock
    WLDock Posts: 3,073
    edited June 2015
    You're going to need more speakers. Just depends on what you want, your room and how far you want to go....5.1, 5.2, 7.1, 7.2, 9.1, 9.2, 10.2, etc.
    IMO, put together a solid 5.1/5.2 with some power behind it. Then, expand from there. I say at least go listen to Atmos, TrueHD, DTS-HD, etc then decide.
