Binding Straps
On the old RT series (Rt3000p, SRT, etc) are the oem binding straps worth a darn, or is it worth it to replace them with a decent set of jumper wires? Anyone have some extra binding straps they would like to sell?
Too many good quotes to list..waiting for some fresh ammo. :)
  • vmaxer
    vmaxer Posts: 5,120
    Make your own with some good wire.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • PolkieMan
    PolkieMan Posts: 2,446
    Check the resistance with a meter
