beautification of my 7s
As I told you guys the '78 7s were rough but absolutely keepers. The grills were way to far gone to even bother w/ a bath and some pegs were broken off. I ordered a set of pegs and a bolt of speaker grill fabric from P/E. I was expecting these next week and they came today and I went right to work. I drilled out the broken pegs and inserted the new ones and then cleaned my table and stretched the fabric w/ what I think are great results. Total work time about 2 1/2hrs. Before you go nuts,yes the logos are missing and I broke 1 and the other was already gone. As for the internals I will send them out and the dude out of respect for the forum asked me not to mix forum and business and will respect that until the results are in. Take a look.xa3gm07pe391.jpg
  • oldrocker
    oldrocker Posts: 2,590
    Looks good to me.
  • [Deleted User]
    [Deleted User] Posts: 10,716
    BIG THUMBS UP!
  • Faustin
    Faustin Posts: 1,151
    Nice. I have the speaker cloth here to re-do my 7's.......just need to find the time.
  • boston1450
    boston1450 Posts: 7,758
    Looks awesome LW. good to see them being saved & enjoyed. Fine job
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • leftwinger57
    leftwinger57 Posts: 2,917
    Because Polk did not use adhesive only 6 million staples I found it to be an easy job. Most rewarding and did not take very much time at all. I already had all of the tools like a sharp razor, T-25 staple gun, hammer and straight edge ruler. The pegs were just as easy and were only needed on 1 speaker. Thanks guys, it really was easy just stretch well and have no creases.
  • vcwatkins
    vcwatkins Posts: 1,992
    Well done, El Dub.
