Monitor 5B and 5jr+ Passive radiator rubber surround
cortico
Hi all, as you know I have been refurbishing my 2 speaker set. I have noticed that the passive radiator rubber surround varies between the two speakers. The 5jr+ has a much softer and thinner rubber than the 5B which appears to be s bit stiffer.
Anyone compared the two and noticed this? I was wondering if the one of the std got the rubbers replaced at some point.
The Jr's are 6.5", the 5B's are 8". The larger PRs have heavier rubber surrounds.
It's normal.Home Theater/2 Channel:
dhsspeakerservice.com/
