Forum searching on an Android phone or tablet problem?
aprazer402
When performing a search of forum posts using my Android phone or tablet, the resulting display of the search will list the posts that matched, just like when using a PC, but as I scroll to the bottom of the list, it will say on the bottom left something like, 55 matches. But only say 20 were displayed above. I have not found a way to view the remaining matches. Is it not possible on a mobile Android phone or tablet to view the remaining found search results on the new Vanilla forum? Just wondering if others have encountered this. Thank you.
Same on iPhone...Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I'll ask.
Thank you to Polk and Vanilla for fixing this. Now when you perform a search on an android phone you are able to view all of the search results. It now shows first, last and arrows to go back and forth at the bottom of each page. Where before you where only able to see one page of the search results and not advance further. Thanks again.
