just checking availability
audiobliss
audiobliss Posts: 12,518
edited August 2004 in Flea Market
I think I've decided that I want an equalizer. I'm not sure why, but I've sorta decided that I want to try to stick with all Yamaha components. Is this a really bad decision? I also would want a tape deck. Dual. Now, I'm not actually interested in buying right now, I was just wonderin' how many of 'em are floatin' around out there and if anybody would recomend I go with another brand or anything. I guess I mgiht should ask this in the 'Electronics' thread....
Thanks.
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
  • steveinaz
    steveinaz Posts: 19,546
    edited August 2004
    Why an EQ? They're tweeter-killers if not setup properly. I would re-think the EQ thing if I were you....
    But, if you're insistant on it, Soundcraftsmen EQ's offer a level adjustment you don't find on most others that reduces the chances of overload. This would be the only EQ I would own.
  • audiobliss
    edited August 2004
    Well, I'll tell ya why I want an EQ. And, you can tell me why it's absurd and why it won't work. When my friend was over this weekend, he brought his DCM KX-10 (I believe), and we had a comparo in regards to bass. The DCM's have 10" woofers. I went into the menu and changed the graphic EQ (a pain) and turned the treble down and the bass up on the front controls on my receiver. I still didn't get a 'lot' of bass. I mean, I guess it was plenty, but it was nothing amazing. My friend's dad has an old (old, old, old) Onkyo receiver. When we hooked up his DCMs to that receiver and turned up the bass, we could rattle everything in his house!!! and that wasn't even maxing out the bass settings. I don't know if this has more to do with the ability of the receiver or what, but I was thinking it would at least be easy to turn up the bass if I had a separate EQ.
    Tell me what y'all think. I'm open to everything.
    Thanks!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited August 2004
    Receiver ? what flavor ? does it have preamp outs ? MAYBE you should be thinking amp instead of equalizer.
  • audiobliss
    edited August 2004
    haha; I'm also thinking of a max of maybe $150!! lol
    Though, it may be an amp that I need. I thought the RX-V1400 was a decent amp, though....
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • wlrandall
    wlrandall Posts: 440
    edited August 2004
    If you do end up gettting an EQ, skip right past the consumer level garbage and get a pro audio unit. Check out dbx, they make some great stuff.
  • steveinaz
    edited August 2004
    Sure, an external EQ will allow you to pump up the bass, but is this the effect you want? It's not a realistic level of bass, and not true to the original mix. You have a nice system, an outboard EQ for the purposes you describe would be 2 steps back, in my opinion. BUT, it's your dollars and your system; look for a used Soundcraftsmen.
    Here:
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3271&item=5716853478&rd=1
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3271&item=5716138807&rd=1
    and a NEW one:
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3280&item=5715857199&rd=1
  • audiobliss
    edited August 2004
    Thanks, steveinaz; I appreciate your advice even though you don't agree with my mission. :D I just kinda like turnin' it up every now and then. Couldn't I still run it straight even if I had an EQ?
    Now, what about dual deck tape players/recorders? Specifically Yamaha units? Anybody know about 'em? If they're still around? What are some better brands I might should look into?
    Thanks!!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited August 2004
    Originally posted by steveinaz
    You have a nice system, an outboard EQ for the purposes you describe would be 2 steps back, in my opinion. [/url]
    Wow!! A nice system?!?! Man, compliments like that'll change my mind all the time, lol. Maybe I don't need an EQ.
    Now, you did say 'for the purposes you describe'; for what purposes do you feel the use of an EQ would be legitimate?
    Thanks!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • wlrandall
    edited August 2004
    Personally, I wouldn't go with a 2/3 octave EQ, there's too much overlap. Check out the dbx 231:
    http://www.dbxpro.com/231.htm
  • steveinaz
    edited August 2004
    EQ's are legitimately used when set-up with a pink noise generator and professional mic, for the purpose of flattening in-room response. Your purpose, as I understand it, is to have a more flexible tone control.
    As far as dual-cassette decks, I don't have clue brotha...been too long for me. I haven't had a cassette deck since 1985.
  • pixiedave
    pixiedave Posts: 227
    edited August 2004
    Thanks!!! [/B]
    Why such antiquated technology?
    And I think you would be better off with two single decks, you may want to adjust the recording level on some low level source, you can't do that with a dubber.
    You never blow your trip forever! < Daevid Allen
  • audiobliss
    edited August 2004
    Are you sure you can't adjust the recording level? I though you could.
    I have a good number of tapes and Dad has a bunch, and I'd like to be able to play them on my system. I also might try putting them on my computer and possibly making CDs. I dunno.
    Thanks!
    And, flexible tone control is exaclty what I was lookin' fer.:D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • wlrandall
    edited August 2004
    Very good point that I second. I use one only for this; in fact my mains are so flat they don't need one when measured at three feet-it's the room that screws everything up.
  • TheReaper
    TheReaper Posts: 636
    edited August 2004
    ...And, flexible tone control is exaclty what I was lookin' fer.:D
    That's why I have one :D , a cheap AudioSource EQ 100 that matches the rest of my system.
    Did you know that MS Media Player has a digital graphic equalizer built in.
    Toshiba 42" RPHDTV (42H83)
    TW Cable (Pioneer Voyager HDTV)
    Toshiba DVD (SD-3900)
    Onkyo 360w 6.1 (TX-SR501B)
    AudioSource EQ 100
    HP 8775C / ATI AIW 9600XT128
    Philips pos DVD/VCR
    Monster MSS4 Speaker Selector
    Acoustic Research short ICs
    Radio Shack long ICs
    Polk R50 L/R Mains
    Polk R30 L/R Surrounds
    Polk CSi40/R50 Center
    Polk R30 Rear Center
    Polk RTi70 L/R B-Mains (A/B bi-amp)
    Sony 10" Sub-Woofer
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • Sami
    Sami Posts: 4,634
    edited August 2004
    That Onkyo probably has much more juice coming out of it than your Yammie, that's why there was more bass coming out of the speakers. Like PolkWannabie said, external amplifier is what you need.
  • steveinaz
    edited August 2004
    I suspect the Onkyo was running a "loudness" circuit as well.
    It's a tough call, sometimes what sounds good isn't really true to the original. Most people have what I call a "bass sweet tooth." And like the sound of (lets call it) reinforced bass. Hey, to each his own; it's your money, your system, and should be setup the way you like it.
  • audiobliss
    edited August 2004
    wait a cotton-pickin' minute!!!! (:D ) You mean to tell me that ol' piece of Onkyo electronics is doin' more 'an 110 watts!! wow......
    I think I'm impressed. Well, I by no means have enough dough for an amp. Besides that, Mom would absolutely KILL me if I laid eyes on another piece of audio equipment in the next 2 years after I got these Klipsch speakers...
    And, I'd say I have that, uhh, bass sweet tooth, lol; I'm not one of those ridin' down the road with a one-note sub rattling the world, but I do like a lot of accurate bass.
    Thanks.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited August 2004
    Thanks for the support!! :D
    What is MS Media Player? I'm using foobar2k on my computer, and it has one. However, I hope to move up to a CD player pretty soon.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Sami
    Sami Posts: 4,634
    edited August 2004
    It all depends on what "old Onkyo" it is. Besides, that Yammie's actual power might be something different than the rated... ;)
  • pixiedave
    edited August 2004
    There might be, but I have never seen one. When I was using casette decks, I was doing some heavy duty Grateful Dead boot trading. I recieved a lot Then again, I havent owned or listened to casettes since 96. I di a lott of concer taping, and that is when i sold my old sony d6 casette recorder for a sony pcm-m1 DAT
  • marly421
    marly421 Posts: 73
    edited August 2004
    Yahama I know little of, but the stuff you want to do, I would go only one way.
    The Pioneer CT-W606DR. Its reasonably priced (around 175. new) and sounds great.
    It will make those old dolby B cassette sparkle. It has a digital processing system with a 20bit a/d to /da converter that works like nothing I've ever heard.
    The s/n ratio is something over 90db's and the music comes out of complete silents even at ear slamming volumes. I have copied many cassette to cd and they simply sound wonderful. Always better than the original tape for sure.
    Dual deck, black face and I will never give her up. With over 2000 cassette...I have good reason.
    M
  • scottnbnj
    scottnbnj Posts: 709
    edited August 2004
    yeah, if you're gonna have an eq, you gotta go for the ring.
    it's worth mentioning though, you can use an eq to muscle a flat response but if you need wild gain swings to get it done there's a good chance the room and gear are being pressed into one type of distortion or another. humbly, i think, like bass eq,.. good gear, placement and treatments first, then tap it with the eq hammer as lightly as possible.
    it's been 20 years since i've paid attention to equalizers and frequency analyzers (around when keying command prompts were all the rage), so i don't know what's available today, but, i'd look for:
    digital, for memory options for different curves (ie near, far, loud, soft, music, movies) and, for me, it would just be easier to work with number values than a slides or knobs.
    if not, more detents than just the 0 gain position or ability to easily read precise positions on the scale.
    controls with a physically long throw from minimum to maximum gain (maybe 3 to 4 inches).
  • danger boy
    danger boy Posts: 15,722
    edited August 2004
    I think most EQ's have bypass switches on em.. so you could bypass it easily if you wanted to.
    I don't think an EQ is a good idea either in most systems. I haven't used an EQ since the early 80's if I remember right. Good equipment ususally won't need any EQ's.
    Curious here to why you want a dual deck cassette player. Those can usually be found all the time in pawn shops and thrift stores.. check Ebay for well built vintage ones. Do they even make new dual cassette decks anymore? :p
    PolkFest 2012, who's going>?
  • audiobliss
    edited August 2004
    thanks, guys
    Marly, I'll look into that Pioneer tape deck; do they still make it?
    Dangerous, I just have a few cassettes I don't wanna give up
    I think I may look into an EQ just for playin' around with. First, though, I may want an A/V rack so my stuff doesn't get so dusty. Seems to me to be a bad thing when you look into the top of your receiver and see dust.
    Thanks!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • gidrah
    gidrah Posts: 3,049
    edited August 2004
    I've got a cheap Realistic EQ that I could let you have for about $18 shipped. It's a seven band 1/3rd octave that works great. I've since gotten a couple of better equalizers and don't really use this one anymore. It's pretty small and only has one tape monitor, but it's quiet as a church mouse and I was happy with it for years.
    Make it Funky! :)
  • marly421
    marly421 Posts: 73
    edited August 2004
    I'll check, not sure if they are still being made or not. Got mine sometime ago.
    Marly
  • audiobliss
    edited August 2004
    Soundsw great, Gidrah. What would the frequency range be that I could adjust? Only one tape monitor? What in the world is that? And, how would I hook it up? Where in my system would it be? What cables would it use?
    I'm clueless here......
    Thanks!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • gidrah
    gidrah Posts: 3,049
    edited August 2004
    I just wanted to check your interest. Since you are interested in it @ the $18.00 price, send me a PM with your address and I'll just send it to you. I'll even throw in some cables.
    Make it Funky! :)
