SRS Project
westmassguy
This was an original 2nd/3rd generation SRS. I have to say, these beasts are a PITA to work on. Sonicaps were used throughout the Hi & Lo-Pass, with the exception of the large Caps in the Sub Bass Drive circuit, where Dayton 5% Caps were used. All Caps were hand matched, Sonicaps by Sonic Craft, and the Daytons by me. Mills MRA-12 Resistors were used. The Existing Clear Jacketed Tweeter wiring was replaced with color-coded #16 gauge Tinned Copper. The Clear Jacketed Leads were really nasty, sticky and heavily oxidized. Same for the Hi-Pass coming off the Binding Posts. New Erse SuperQ Sub Bass Drive Inductors rounded out the upgraded components.
Due to the size of the New Caps, Supplemental Riser Boards were fabricated, and additional standoffs installed on the circuit boards, and at the ends connecting them to the large spool Inductors for added support. All in all, a fun project, and another Big Beauty brought up to modern standards.
Home Theater/2 Channel:
dhsspeakerservice.com/
Now that really came out nice! Plus it sounds like he needed this upgrade badly! WTG Dave! Another SRS given a new leash on life and another owner is going to be smiling.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Thanks BrotherHome Theater/2 Channel:
dhsspeakerservice.com/ -
jeeze, look at that stack!
nice stuff, man, very nice.
how old would you say the OE stuff was?
prob what my guts look like.I disabled signatures. -
Thanks. Circa 85' or 86'. 4th and 5th generation were re-designed with a common, smaller circuit board for all SDA/SRS modelsHome Theater/2 Channel:
Why would someone put a new leash on the life of a pair of SRS's when they could give them a new lease on life?Another SRS given a new leash on life and another owner is going to be smiling.
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I don't know: Perhaps he wants them to rein in life, rather than have life control them with some contract only lawyers can understand.
Just a thought!
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
Geez seeing these upgrade crossover threads is pushing me towards "attempting" some crossover work...not to my SDAs to begin with though, my Monitor 5s...they are begging for a refresh.
Great crossover to get your feet wet.Home Theater/2 Channel:
Moose68Bash wrote: »
Just a thought!
Give him a break. Darryl's brain is so far above ordinary men, that his poor fingers can't keep up
LOL I was definitely finger tied at the moment, I can't believe I put SRS instead of SDA
Amazing work by an Amazing person! Whoever is lucky enough to work with David will quickly realize he does everything to the extreme quality that the job he's doing is getting 100%, 100% of the time. We are blessed to have him here and very proud to call him my friend!!!"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
Thank you Mr. Ripper, now where do I send the check?tophatjohnny wrote: »Amazing work by an Amazing person! Whoever is lucky enough to work with David will quickly realize he does everything to the extreme quality that the job he's doing is getting 100%, 100% of the time. We are blessed to have him here and very proud to call him my friend!!!
Just do them one at a time, so you can refer back to the original layout and solder points. If this is something you're going to do once in a great while, there's a 50 watt adjustable iron that will do the job. Your typical 20-25 watt pencil iron won't heat up the copper traces enough to make a good, smooth solder joint.westmassguy wrote: »
Yeah, should be simple enough that if I do screw things up, fixing them won't be too difficult. Just have to unscrew the terminal cup one of these days and investigate whats in there and scrounge for parts, also pick up a decent iron to do the work.
Rat Shack, if they're still around by you, used to carry it.
Man that's a heck of a stack of caps! Nice work!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
westmassguy wrote: »Just do them one at a time, so you can refer back to the original layout and solder points. If this is something you're going to do once in a great while, there's a 50 watt adjustable iron that will do the job. Your typical 20-25 watt pencil iron won't heat up the copper traces enough to make a good, smooth solder joint.
Rat Shack went the way of the Dodo bird over a decade ago. Kinda miss the 'ol Radio Shack...used to have those hard to find interesting things.
Ours just closed last yearHome Theater/2 Channel:
We don't have a complete library of the older Monitors unfortunately.Home Theater/2 Channel:
I did my Monitor 4's myself with Dave's advise to help me. Took one look at my 10's and said no way! I wanted them done right
Said they same thing about my CRS's too. 2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Was my pleasure Brother.I did my Monitor 4's myself with Dave's advise to help me. Took one look at my 10's and said no way! I wanted them done right
nbrowser- is this what your m5 crossovers look like? Mine are dated 1980
Here are the upgrades- thanks to David for advice
Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
Power Amp: Sunfire Architect's Choice Series II
Preamp: Adcom GFP-750
SACD/CD: Oppo BDP-95
Tuner: Sansui TU-717
TT: Technics SL-MA1
Phono Pre: Emotiva XPS-1
Music Server: Mac Mini w/JRiver - iPad w/JRemote
DAC: Eastern Electric MiniMax Plus
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5 -
The SRS crossovers at the beginning of this thread are mine. David is a great guy and was really patient with me and did a super job on the rebuild. Speakers are in the break-in stage right now with about 50 hours on them. They sounded fantastic from the beginning. Looking forward to hearing the difference after a few hundred hours. Thanks again David!Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
TT: Technics SL-MA1
Congrats on the rebuild,Dave did my 2.3tl's and I couldn't be happier.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
Was my pleasure Sir. Enjoy those Big Beauties!The SRS crossovers at the beginning of this thread are mine. David is a great guy and was really patient with me and did a super job on the rebuild. Speakers are in the break-in stage right now with about 50 hours on them. They sounded fantastic from the beginning. Looking forward to hearing the difference after a few hundred hours. Thanks again David!
