New Tube CDP, Eastern Electric Minimax, a Question, and I'm an Audioholic
MrBuhl
MrBuhl Posts: 2,419
edited May 2015 in 2 Channel Audio
Well - the wife and kids are out of town this weekend, so Dad's left to his own devices... never a good thing for the cash stash! Of course, I made good use of the time, four thrift stores and one community yard sale. Picked up many great CD and LP titles for the listening pleasure! I've also been loosely looking for a different CDP than my Sony S9000's (which I love, and are grossly overbuilt and sound good in my system... but... see "audioholic")
So - to make a long story long, I'm standing at the checkout at GW with a few CD's and albums, and notice a piece of 'lectronics sitting there. Hmm... Eastern Electric, never heard of it. Seems to have tube outputs though, interesting. Go home, research online, consult the Polkie oracle (search archived threads) hmm... seems to get pretty good reviews. @BlueMDPicker seemed to dig his. Go back to GW, still there, sign says, "ask at counter for remote" - of course, they can't find the remote. "Can you come back tomorrow sir? No, I'm sorry sir, we cannot hold it for you till we find the remote". Grr.
Go back this morning, find remote, take headphones (after reading 6Moons review) to test, yep, sounds pretty darn good. All functions seem to work, plays and sounds nice through phones, tubes light up, missing power button is all and a small ding on the LF corner. OK - I''ll take it.
Bring home, install in 2 Channel Rig, put on Carmina Burana (Shaw, Telarc - GREAT recording BTW). In a word, sounds amazing! Very easy to listen to, transients are fantastic. We may have something here. $285 all in with tax and remote - which I thought was a pretty decent deal.
Now my questions - now that it's warmed up a bit, (preheated an hour - and an hour listening) there seems to be a light crackling in the speaks, turn off for a minute, restart, plays silent and ok and then crackling starts. Do I have a bad tube by chance? Something else? Not worth at fix and this price or I did well enough i have room to work? Probably can pickup replacement power button online?
Many thanks - Happy Memorial Day all!
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
  • MrBuhl
    MrBuhl Posts: 2,419
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • marvda1
    marvda1 Posts: 4,952
    edited May 2015
    is it in one or both speakers? if it's in one speaker, change tubes around and see if it moves with the tubes.
    Puritan PSM156
  • MrBuhl
    MrBuhl Posts: 2,419
    Great idea! Thanks - I'll try it!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • MrBuhl
    MrBuhl Posts: 2,419
    Switch is on - it has Electro Harmonix 6922's - look to be recent made in Russia. - date code '07. Letting her heat up.
    Man - when it ain't crackling, this thing sounds so musical. JT on now - like having him in my living room! Effortless. And I'm sure there's WAY better tubes out there to roll in!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • MrBuhl
    MrBuhl Posts: 2,419
    dang it all - same crackling back again after about one disc. Both speakers.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • hochpt21
    hochpt21 Posts: 5,423
    Holy moly...great deal!!
    I could be wrong, but I think that is what @HEINEY_9 moved on to after selling me his dared.
    EndersShadow Posts: 17,707
    edited May 2015
    hochpt21 wrote: »
    He moved onto a line stage preamp from them. This is a CD player
  • hochpt21
    hochpt21 wrote: »
    Hence the CDP... Lol :)
    F1nut Posts: 51,813
    Could be any of the following. Bad tubes, cold solder joint(s), bad cables or a cracked board.
  • WilliamM2
    WilliamM2 Posts: 4,807
    hochpt21 wrote: »
    Not if it's broken. Hopefully they have a decent return policy.
  • MrBuhl
    MrBuhl Posts: 2,419
    well - you step away for a few hours and come back to that... and that doesn't sound good. Take it there's no easy diagnosis and it's probably better to return it?
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
    F1nut Posts: 51,813
    Depends on what you call easy. Swapping tubes is easy for anyone. Checking the rest depends on your skill set.
    F1nut Posts: 51,813
    edited May 2015
    Oops, swapping cables is easy too.
    tonyb Posts: 33,072
    MrBuhl wrote: »
    Now you know why many go bonkers over tube gear. Can't beat the musicality with a stick. Fantastic deal there too, worth having it checked out.
  • hochpt21
    WilliamM2 wrote: »
    hochpt21 wrote: »
    True.
    However, when I posted that I was thinking it was the preamp. In which case your statement would still be true but would at least justify the double exclamation points.
    heiney9 Posts: 25,450
    Get some deoxit and try cleaning the tube pins. This usually works for 50+ year old tubes. Perhaps the newer tubes haven't had time to build up nasty oxidation. I have a large bottle of deoxit as no tube goes in unless it's well cleaned.
    Hopefully the issue is minor. EE stuff is built really well, not the typical "Chinese build" my pre-amp is point to point except for the input/output jacks.
    Check cables as well, can't tell you how many times either a dirty tube or bad cable was the issue.
    I'd also try another pair of tubes just to rule out a bad tube. I don't have any 6922, 6DJ8's or I'd offer you a pair to test and see if it's the tubes.
  • MrBuhl
    MrBuhl Posts: 2,419
    edited May 2015
    @F1nut - Thanks, sounds like I start with cables, which I have, then tubes, which I'll need to get - but likely wanted to try different tubes anyway (the Electro Harmonix turned out to be the better gold ones which is nice). I can do that easy. Skill set is willing, but untrained.
    @heiney9 - Thank you - I'll grab a set of different tubes to test. I have Deoxit and Deoxit Gold - is one better than the other.
    @tonyb - yea - it really sounds astoundingly different as you know - I was very surprised, because I actually really like the sound of my Sonys.
    @hochpt21 - Thanks! Still excited - hopefully I'll dodge the tube bullet!
    So general consensus seems like - hopefully its something simple, no guarantees, but it's probably worth checking out. I checked return policy, and it's not great - store credit only, so if this is worth fixing, it's probably worth my time to try some cheap fixes vs. Have a $300 credit at GW.
    Many thanks all for your time and expertise and advice!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • george daniel
    george daniel Posts: 12,096
    Lol,,, the magic is back!
  • MrBuhl
    MrBuhl Posts: 2,419
    Whelp...
    Switched in a new set of SC Analog 2's - still crackly.
    Switched to a different input on the Dodd - (moved from Aux 1 to CD) - still crackly.
    Switched (just for S&G's) back in my Sony S9000ES - no crackly.
    That's three cheap & easys down - Deoxit and new tubes still to go...
    Had a dumb question/thought - could there be some kind of an electrical or gain mismatch between the Dodd and the EE CDP? Maybe I'll try running it into the Pio Elite on the HT side and see if static is still there...
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
    tonyb Posts: 33,072
    Wouldn't sound like that if it was. The Deox and the tube suggestions are first order.
  • marvda1
    edited May 2015
    try a pencil eraser to clean the tube pins. then take a little contact cleaner on a q-tip to clean the eraser residue off.
    Puritan PSM156
  • MrBuhl
    MrBuhl Posts: 2,419
    OK thanks all - cleaning pins and deoxit tonight - keeping fingers crossed. I have 7 days to figure it out or return and have a very large GW store credit LOL.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
    tonyb Posts: 33,072
    You'll never know for sure unless you also swap the tubes out. With so little time left for a return, probably won't happen in that time frame.
  • MrBuhl
    MrBuhl Posts: 2,419
    @tonyb I've got a set of NOS Phillips JAN 6922 due to arrive today at home, so hopefully I can test them out tonight! Figured that was a worthwhile and relatively small investment. I'll let you know how I make out!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
    tonyb Posts: 33,072
    Cool man, didn't realize that. If the new tubes work with solving the issue, you going to keep that puppy ? That tube sound is certainly addicting.
  • MrBuhl
    MrBuhl Posts: 2,419
    edited May 2015
    @Tonyb - Absolutely, this isn't a turn and burn, it's a keeper - I'll just keep the Sony for SACD playback and such. I'm addicted to the small snippets of juicy goodness I've already experienced. In fact, I've started looking around for tube CDP options if this one doesn't work out.
    BTW, warmed up the EE with the new Phillips tubes for an hour while I fired some burgers on the grill (its National Hamburger Day afterall). Just popped in my Red Seal recording of
    Van Cliburn - Tchaikovsky No 1 and Rachmaninoff No 2 CD. This one produced immediate static previously - 13 min in to Tchaikovsky and so far so good!!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • MrBuhl
    MrBuhl Posts: 2,419
    Keeping my fingers crossed @Zero !!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • MrBuhl
    MrBuhl Posts: 2,419
    Seems to be the case Dskip - most of the way through King Crimson's In the Court of the Crimson King now - still no static. I may have dodged the bullet after all! I'm starting to get hopeful/excited!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • vmaxer
    vmaxer Posts: 5,120
    MrBuhl wrote: »
    Good luck, hope it works out for you!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
