RM6005 question.
cchiu
cchiu Posts: 3
Hi,
I'm considering purchasing a new, entry-level home audio system and was considering the Polk RM6005. J&R has it for a great price but it doesn't come with the sub woofer. Do I have to buy a Polk sub to do with it or could I go with another brand? Would you recommend this?
Thanks for any help and opinions!
Cart
Post edited by cchiu on
  • gatemplin
    gatemplin Posts: 1,595
    edited August 2004
    Welcome to CP,
    You can go with any sub you want. Check out www.creativesound.ca www.svsubwoofers.com www.hsuresearch.com www.adireaudio.com
    SV subwoofers has a new sub and there will be a pre-order soon, pretty hard to beat the pb10-isd for $400.
    Graham
  • Willow
    Willow Posts: 11,233
    edited August 2004
    can't find the bass extension for the new PB10 isd it goes down to what ??
  • cchiu
    cchiu Posts: 3
    edited August 2004
    Thanks for the replies guys. I'm definitely not looking to spend a lot on a sub woofer. I'm looking on E-bay now for something decent and used.
    Any opinion on Panasonic audio equipment?
    If things don't work out on E-Bay, I'll go and buy a PA sub from J&R. They have great prices!!
  • lomic
    lomic Posts: 407
    edited August 2004
    Just remember that a SVS or HSU sub will not only make your entire system sound much better, but will be the one piece you need not upgrade if you're thinking of moving past entry level HT in a year or two.
    If it is just too far out of your price range for one of these, I believe the Velodyne CHT-10 would do well, which is around $250 IIRC.
    If you just want to pick up a little HTInABox sub, I doubt anyone in these forums will give a recommedation for any :)
    Dodd Audio ELP [ Tubes ] // Harman Kardon AVR330 // Parasound HCA-1203A // Denon DVD-2900
    Polk Audio LSi9, LSiC, LSi 7 // HSU STF-2 // Signal Cable Interconnects (SG BW/A2/MP)
