Best older universal for CD playback??
geppy1
I am wondering if anyone has compared the universal players below for CD playback sound and what were your observations. I am trying to stick with one machine verses one for DVD and one for CD but that can be tough I cannot afford the newer units and to me many are hyper detailed and not what I am looking for. I have heard the DVD 7001 and DVD 3800 and thought the Denon was warmer. Probably the ALPHA processing. I had that on my Denon 1650AR I had for 9 years and it did make it more musical and analog. Thanks
Marantz DV 7001,DV 9500,DV 9600
Denon DVD 3800,DVD 3910,DVD 3800BD,DVD 2930ci
I would stay away from the Marantz...
I had a DV7600 that was nothing but problems. IMO, they have an issue making a "universal" player.
IIRC, some of the Pioneer Elite units are pretty damn good. -
I've owned a Denon 5910 for years and love it. But I play 95% of my music analog.
Because I am The Pumpkinking
I'll second the older Pioneers. An AVI59 or 79 can be had for around 100 bucks and are great as cdp's.HT SYSTEM-
lsi 9's -
No Oppo on your list?"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
I have an Oppo and while it does indeed sound better to me than my Pioneer, the old DV-563A is a very close second if you can make up for it's lackluster bass management and for the $$ I think it's a very good buy if you can find one.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
It seems that budget is really important here. Those higher end Denons (3910) can go for over 200 used, which opens up some other options. I just purchased a Marantz UD5007 through accessories4less and am loving it so far, and it adds bdp to the mix for 3 bones refurbished. And CDs sound really good through the 2 channel analog out. BUT I need to get my hands on some sacds and dvd-as to evaluate that aspect. I sold mine off years ago for a pittance and now I am kicking myself as re-purchasing them is cost prohibitive...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I'd also shy away from the Denon's unless you get for very cheap. They are getting long in the tooth and were never know for long lasting lasers. I type this owning both a 2900 and a 3910 and both are starting to have laser problems on a lot of my CD's. They both will not read any "Tool" cd's and many more that escape me now typing this. They will read every SACD and DVD-Audio I put into them, but talking to my great tech he told me I was very lucky to have them issue free for so long.
I will end this with it took 4 2900 units to finally get one that worked right and they were all brand new. trust me you never want to deal with D & M holdings for any warranty work EVER. -
The poneer DV 79avi also comes to mind
I've got a Pioneer BDP-51 that needs a new home. PM if interested. I only used it for CD's since the blu rays take so long to load. These can have laser issues with blu rays though. Mine read some fine and on some newer ones would have issues. Did updates to it but still had some bugs. If you only want for cd playback would be great for under $125 plus shipping.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
My Pioneer DV-47A is still going strong and continues to read all of my discs so far.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I agree, my Pioneer BDP-95 sounds great.
Did a side by side with the oppo103, almost sound the same. One not being any better than the other.B&W CM9Classé Sigma -
My Denon DVD-2910 sounds and works very nice since I replaced the laser pickup. I have an Oppo DV-981HD that sounded good until the power supply board fried. This seems to be a frequent issue with this unit. Oppo doesn't sell repair parts but will fix it if I buy the extended warranty for around $50. I had hoped to use the Oppo while I did some mods to the 2910.Stan
Main 2ch:
HT:
Other stuff:
pumpkinman wrote: »I've owned a Denon 5910 for years and love it. But I play 95% of my music analog.
The Denon DVD-5910 is very good, IMO too.
Edit: I have owned mine since 2006 and have never had a single issue with it; it works flawlessly.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
The Older Universal Players where great CD players.
My Favorites where the Pioneer Elite's and the Denon's. Can't go wrong there as they both had excellent CD playback.
If DVD Audio isn't in the cards then strongly look for older Sony ES stuff. I got a 9000es and it's amazing for CD play back. I put it into my system from time to time just to play with it.Dan
True about the Sony ES. I have a CDP 650esD that is silky.Stan
Main 2ch:
HT:
Other stuff:
And the elites play SACDSpeakers: SDA-1C (most all the goodies)
+3 on the Sony ES series, I have two S9000ES, one for each rig, and they are built like tanks, sound absolutely great with my current rig(s), and play most anything except blueray! Grossly overbuilt. Component video only though - no HDMI.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
My Marantz DV-9500 has laser issues. Doesn't like to read SACD at present, but still is good with CD and DVDA. I bought a replacement laser unit pretty cheap, but have yet to investigate installing it.Jay
Usually there is a shorted solder bridge on optical readers that must be removed after it's installed. Protects it from handling static discharge and all that....
