The Elusive Monitor 12
westmassguy
These are certainly rare, and an odd bird with respect to the crossovers. There are two versions, the original and revised. This set of crossovers were the revised version. They added a current sensing contour network to protect the tweeter. I had always thought Polyswitches were eliminated by 1990, however the revised crossovers added a Polyswitch shunted with a 4.2uf Capacitor. I had intended to replace the Polyswitch with a .5 ohm Resistor, which is what we normally do, however this would nullify the protection aspect, and add yet another Contour Network downstream from the first. I contacted Ken, who explained its purpose. We both agreed, instead of replacing the Polyswitch with a fixed Resistor, just eliminate the network altogether. The Crossover would then be identical to the original Monitor 12.
This particular pair used the new, square circuit board, so mounting components would be more challenging.
Clarity ESAs were chosen for the Hi and Lo-Pass, Mills Resistors, and Cardas Binding Posts rounded out the remaining upgrades. All the original inductors were retained. Clarity doesn't make a 16.4uf Cap, so two 8.2ufs in parallel were used for the Lo-Pas Shunt. The Mills Resistors were relocated to the bottom of the board. New heavier lead wires were installed along with the Cardas Binding Posts. It still amazes me that Polk used #18 gauge lead wires from the Binding Posts to the Circuit Boards on all the old Monitors.
All new components were secured with 3M VHB Tape, Nylon Wire ties, and Cardas Quad-Eutectic Solder was used throughout.
Home Theater/2 Channel:
dhsspeakerservice.com/
Wow those are rare. Great job.
Nice, after having you put those Cardas binding post on my 10's I have really grown to like them!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
They are nice. Expensive, but nice.Nice, after having you put those Cardas binding post on my 10's I have really grown to like them!
dhsspeakerservice.com/ -
How did this effect the sound? What about dynamat on baskets and norez behind mids?Speakers: SDA-1C (most all the goodies)
They're not my crossoversHow did this effect the sound? What about dynamat on baskets and norez behind mids?
The size differences in those caps is amazing. Hard to believe they do the same job that those little ones did. Can't imagine the difference in sound. Makes me want! Thanks for posting- SDA 2B (1989, Oak Tops, 194s, Spikes)
- Monitor 7B (1982 Peerless, Sonicaps, Mills, BH5, JB Welded, Binding Posts)
- (2) SVS SB12-NSD (Flat Black)
- SVS SB 3000 (Gloss Black)
- Pioneer SC-1222K AVR
- Marantz MM 7055 (5 Ch Amp)
- Pioneer PD-D6 SACD Player
- Marantz NR1403 AVR
- Sony UBP-X800M2 (4k Blu-ray)
- Sony UBP-X1100ES (4K Blu-ray)
- Adcom GFA 555 Amp
- Monitor 5 (194s, Side Surrounds)
- Monitor 5Jr+ (194s) {Storage}
- LG OLED65CXPUA (4K OLED TV)
- LG 55UN7300PUF (4K HD TV)
- RT35i (Cherry)
- (2 Pair) RT25i (Cherry)
- CS400 (Center)
- CS350 (Center)
- F/Xi A4 (Rear Surrounds)
- RT25 (Rear Surrounds) {Storage}
- Audioquest Interconnects
- Blu-Jean Speaker Cables & Interconnects
" But boy do I remember the strain of her refrain " LG -
You're welcome. NP Electrolytics are tiny compared to Metalized Polypropylene CapsHome Theater/2 Channel:
