Lost my Polk surround bar 3000 remote control
Can I program my cable remote control to work the Polk surround bar?
Best Answer
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Answer ✓
    Hello,
    Welcome to Polk's forum. Most of the time a cable remote isn't a good choice to use. Rather try using the TV's remote for programming and since the cable remote should operate the TV it will operate the Polk. You can also find replacement remotes from Polk's CS department at 1-800-377-7655.
    Regards, Ken
