Grills on or off
Do you listen to music with speakers grills on or off? My Dynaudio s5.4 sound better with grills off to my ears.
  • vmaxer
    vmaxer Posts: 5,120
    Off
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Nightfall
    Nightfall Posts: 10,084
    On. The top hats on my speakers have diffraction plates that keep the high frequencies from bouncing off the top of the cabinets, they sound better on. That aside, it keeps the dust off the drivers and top crossover.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited May 2015
    With my SDA 2As and my Monitor 7As I never noticed a difference with the grills on or off. I did quite a few comparisons both ways, and was never able to. I haven't done any comparisons with the LSi9 grills on or off. I had them off for my first couple of listening sessions just because I wanted to look at the drivers. They've been on since then.
    For whatever it's worth, many high end speakers are designed to be used with the grills in place. The slight diffraction effects of the grill fabric can be taken into account in tuning a speaker, and often is with very high end offerings.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    F1nut Posts: 51,776
    This
    SCompRacer Posts: 9,112
    edited May 2015
    I've read manufacturer claims that grill cloth tends to diminish only high frequencies and slightly. Diffraction could occur from the grill frames and more likely measure higher and be more audible than say a 1/3dB high frequency dip through cloth.
    You could always ask a manufacturer if they measure response with grills on or off if not indicated in the specs.
  • BlueFox
    BlueFox Posts: 15,251
    Off. Magico designs their speakers to be without grills, and the top of line models do not even have grills. The grill on the S5 is designed to protect the speakers from damage, for example during parties. However, they obviously impact the sound, so off they come when it's time to listen for pleasure.
  • vc69
    vc69 Posts: 2,500
    I like 'em off unless the grandkids are around.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • comfortablycurt
    nbrowser wrote: »
    Peerless Monitor 5s, off because the grill has minimal impact to my ears and I love seeing the look on people's faces when you tell em the 8 inch woofer isn't a woofer at all.
    I often left the grills off of my Monitor 7As and my SDA 2As for this very reason. The 2As have flat cones in the passive radiators, and a lot of people comment on how strange looking the woofers are. When I explain the passive radiator design and show them the PR push-test, most people find it really interesting. It's something that most people aren't familiar with though in my experience.
  • Joey_V
    Joey_V Posts: 8,600
    edited May 2015
    Depends.
    BW PM1 I left on. BW 802 Diamonds I take off.
    tonyb Posts: 33,072
    Shouldn't the more appropriate question be.....pants on or off ?
  • Joey_V
    Joey_V Posts: 8,600
    tonyb wrote: »
    Ooooh kaaaay.... Bahahaha
  • Joey_V
    Joey_V Posts: 8,600
    nbrowser wrote: »
    tonyb wrote: »
    Remember that line the next time you lock yourself out of the house in just your robe in the middle of winter ya senile ol f a r t! :)
    Locked out in the wintry Chicago cold.... let's see who'll be laughing then.
  • ken brydson
    ken brydson Posts: 9,003
    Joey_V wrote: »
    nbrowser wrote: »
    tonyb wrote: »
    Maybe you missed it. Actually happened...
  • Joey_V
    Joey_V Posts: 8,600
    That is soooo hilarious... job well done Tony!!!
  • westmassguy
    westmassguy Posts: 6,850
    For vintage Polks, grills on. The cones are naturally tacky, and the grills keep them relatively free from dust accumulation. If your worried about high frequency roll-off, replace the grill cloth. The original cloth is mediocre at best.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • leftwinger57
    leftwinger57 Posts: 2,917
    Using mine both ways I hear absolutely no difference but I'm only 9' away. I do like to gawk at them so for the most part grills off except now nearing the summer I keep the grills on do cover them up when the sun streams in which I showed on another post.
    tonyb Posts: 33,072
    nbrowser wrote: »
    tonyb wrote: »
    LOL.....you guys aren't going to let that one rest are ya ?
    Speaker grills ? On or off doesn't matter but I find it's a more mood dependent thing for me.
    btw KKKKEN, if I had a nickel for every hockey puck you Cannucks chewed on up there, I'd be a rich senile old ****. ;)
  • vmaxer
    vmaxer Posts: 5,120
    Joey_V wrote: »
    Agreed, had to go back and read the thread again.. :D
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited May 2015
    I consider the grills to be just like the hood on a car. Unless you are at a car show or have more invested in chrome than paint, leave the hood down. SRS top models or huge line arrays designed for open display, would be my exception.
    I always chuckled at the car club guys with the '60s Impalas that cruised with the hood off. I do like some of those exotic mid engined jobs that have windows for hoods though....
  • mikeyb128
    mikeyb128 Posts: 2,885
    Been moving over the past few weeks. 2 channel system went up first as it is the easiest, grills off for cleaning and am really loving the sound. Including boxes, bare hardwood floors and crap all over the house.
    2 channel:
    Theater:
  • Jetmaker737
    Jetmaker737 Posts: 1,118
    Off. I just like to look at my drivers. Sound difference is negligible to me.
    tonyb Posts: 33,072
    Now that's the same reason I listen with pants off. :)
  • Upstatemax
    Upstatemax Posts: 2,737
    I usually like them off.
    However, with my children they stay on...
  • TCK
    TCK Posts: 231
    Off now, but I go back and forth. They look louder with them off, more refined with them on. I'm just glad they are still in good shape to have the option.
    - SDA 2B (1989, Oak Tops, 194s, Spikes)
    - Monitor 7B (1982 Peerless, Sonicaps, Mills, BH5, JB Welded, Binding Posts)
    - (2) SVS SB12-NSD (Flat Black)
    - SVS SB 3000 (Gloss Black)
    - Pioneer SC-1222K AVR
    - Marantz MM 7055 (5 Ch Amp)
    - Pioneer PD-D6 SACD Player
    - Marantz NR1403 AVR
    - Sony UBP-X800M2 (4k Blu-ray)
    - Sony UBP-X1100ES (4K Blu-ray)
    - Adcom GFA 555 Amp
    - Monitor 5 (194s, Side Surrounds)
    - Monitor 5Jr+ (194s) {Storage}
    - LG OLED65CXPUA (4K OLED TV)
    - LG 55UN7300PUF (4K HD TV)
    - RT35i (Cherry)
    - (2 Pair) RT25i (Cherry)
    - CS400 (Center)
    - CS350 (Center)
    - F/Xi A4 (Rear Surrounds)
    - RT25 (Rear Surrounds) {Storage}
    - Audioquest Interconnects
    - Blu-Jean Speaker Cables & Interconnects
    " But boy do I remember the strain of her refrain " LG
  • Mikey081057
    Mikey081057 Posts: 7,127
    off... if it looks better it sounds better
    Garage | Polk Monitor 5B's
  • Emlyn
    Emlyn Posts: 4,710
    Depends on the speaker. I listen to LsiM speakers with the grills off. SDAs with the grills on. I also have a pair of Spendor speakers I use once in a while that are designed to be used with the grills on. The cabinets on those are thin walled and the design of the grills, which are fairly thick mdf for the frame add to the solidity of the front baffle of the speaker overall.
  • Mikey081057
    Emlyn wrote: »
    Actually I do the same... Grills on for the SDA's off for the LSIM's...
  • RamZet
    RamZet Posts: 792
    I leave mine on when im not using them. When i use them i take them off. Very easy to do bc they are magnetic.
    B&W CM9Classé Sigma
  • leftwinger57
    Since this thread is still kinda going on I'll give you the 2 most ugliest grill off speakers ever made.
    1. AR 3As, w/ that tape and whatever else that's is going on looks terrible.
    2. Probably the worst for me has got to be Dahlquist D-10s. With that patch work of speakers, some mounted on masonite that looks haphazardly placed and that open grilled rear that has got to be the biggest dust collector known to mankind. Now w/ saying all that w/ grills and stands and the right power they do sound great.
    http://www.syer.net/dahlquist.htm
  • ukcolin99
    ukcolin99 Posts: 286
    This is no Bi-wire forum and I know I am not high end, always feel the 705's sound better with grills off- 2 channel all music w/volume. Glad I'm not the only one.
